P0011 - Valve Timing Control Solenoid
Old Dec 17, 2012 | 04:58 PM
  #31
dj714's Avatar
Yup bank 1
Old Dec 17, 2012 | 05:11 PM
  #32
jhatfie4's Avatar
I think you need to check the physical connections from the solenoid to the ECU, make sure your cam sensors are installed correctly, make sure your oil level is high enough
Old Sep 9, 2019 | 12:06 AM
  #33
Jonah Urban's Avatar
2007 g35x
what year i have an 2007 g35x and there is 2 hoses in the way from the solenoid sliding out how do i get it out?
Old Sep 11, 2019 | 02:24 AM
  #34
2007 g35x
so how do you fix this??? plz help??
Old Sep 11, 2019 | 02:25 AM
  #35
2007 g35x
did u end up getting the vtc out?? or fix the problem I am having the same!!
Old Oct 29, 2019 | 11:14 PM
  #36
2007 g35x
you have to move the wire clamp down that is holding the big tube(comes from your rad into engine) and then there is one that is much thinner and is held on by a metal tube that the other tube goes in u have to go under your car and unbolt 3 bolts(that tube connects into your oil filter) once you take out the 3 bolts push it down and will have enough room to slide the solenoid out but it is still very tight msg back if you need photos hope you get it
jsimonk
Dec 22, 2023 03:49 PM
Muski_G
Dec 1, 2023 11:11 AM
ghost_g35
Aug 7, 2015 10:31 AM
KevinnnVo
Jul 28, 2015 06:29 PM
lemmy999
Jul 25, 2015 12:13 PM
