DIY : Oil Cooler O-ring Replacement V35
Old 02-20-2013, 01:21 AM
Jaygotboost's Avatar
Post DIY : Oil Cooler O-ring Replacement V35
I recently replaced my oil pan gasket due to a bad leak and was shocked to see oil still dripping ( pretty bad leak ) , upon further investigation saw that the oil came from behind the oil cooler . Did some searching on here and saw this was a common issue with our cars , so I immediately began to search for a DIY and none came up, I called Cerritos Infiniti and they charged $275 for the work , so I decided to do it myself and make a DIY thread .
Tools :
pliers
ratchet 1/2 drive
14mm socket
22mm deep socket
( container ) something to drain the oil / coolant in
paper towels
degreaser
Q-tips
Parts : O-ring part # 21304-JA11A ( paid $16 )
Step # 1
Drain oil into container from drain bolt with 14mm socket ( pictured below )
Step # 2
Remove oil filter ( pic below )
Step # 3
Remove connector bolt with 22mm deep socket ( pic below )
Step # 4
Remove lower coolant hose from oil cooler using pliers and let coolant drain into container
Then remove upper hose connected to oil cooler ( oil cooler is free at this point )
Step # 5
Clean oil cooler ( mine had a lot of grime and build up )
remove old o-ring
( how it looks cleaned up )
Step # 6
Replace O-ring lubricate top of O-ring with oil
Step # 7
Clean mating surface on engine ( where oil cooler bolts on )
NOT PICTURED
Step # 8
Slowly center oil cooler with connecting bolt inside and begin to screw it in
Angled pipe goes to top coolant hose and straight shorter pipe to lower coolant hose
I hand tightened first bolt first, secured hoses in original spots and then used pliers
to pinch clamps on to original location
Torque connector bolt to spec 36ft/lbs
Step # 9
Screw oil filter back on
Double check your work
Should look like this
Step # 10
Add oil / coolant and check for leaks
File Type: jpg
The following 9 users liked this post by Jaygotboost:
Blue Dream (02-20-2013), BradMD_96 (01-14-2016), dsr30 (12-25-2014), gnordmeyer (04-26-2019), Lazy912 (03-02-2013), saywat? (02-20-2013), Scottwax (04-07-2018), VinnyBacon (04-20-2018), vk45de (01-19-2016) and 4 others liked this post. (Show less...)
Old 02-20-2013, 03:50 AM
Did this about two months ago. Stopped my leak
Old 02-20-2013, 09:47 AM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
Good stuff, thanks for the DIY.
Old 02-20-2013, 01:52 PM
FTW - It was pretty easy and resolved a PITA leak ...
Old 02-20-2013, 01:53 PM
NP man , anything to help out the forum fam , I am sure this should help many others with mystery leaks and helping troubleshoot .
Old 02-20-2013, 02:37 PM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
Very common.... good job, but 16$???
21304-JA11A $3.25 shipped (US Mail) $7.00 shipped (USPS Tracked)
just in case someone needs one
Jaygotboost (02-20-2013)
Old 02-20-2013, 02:53 PM
Yup Cerritos Infiniti charged that much , being that I needed it right then and there I had no choice . But I did see that you have them much cheaper , I posted a pic with receipt because I knew I was paying $10 more lol
Old 02-20-2013, 03:01 PM
PREMIUM SPONSOR
yeah I can understand sense of urgency means sometimes you'll pay more....
but at least you got it done and done right
Old 02-20-2013, 03:16 PM
thanks I am glad It is finally done , for some reason Cerritos Infiniti is much more expensive than other dealers further out , maybe location . They sit in a super high traffic area and are always full
Old 02-20-2013, 10:48 PM
Tolboothwilley™'s Avatar
Good call - many people ask about this. Nice to have a write up to shop how simple of a fix it really is
Old 02-21-2013, 01:16 AM
Pretty simple and not much skill required for this simple job . Too many oil leak threads
Old 03-01-2013, 12:50 PM
gtrefever's Avatar
So happy to see this! I've had a bad leak and couldn't figure out where it was coming from! It wasn't from the pan or filter. I figured it was the Oilcooler O ring.
Old 03-02-2013, 06:37 AM
I'm going to edit and add bleeding the cooling system which is a vital part of this process
Old 03-02-2013, 07:19 PM
Lazy912's Avatar
Cool, I'm looking forward to it. I'll be doing all of this myself. Went to the dealer this past week and had my oil change, they said the o-ring for the oil cooler is bad and that's why I'm leaking. They wanted $156 to replace the o-ring. And what do I see when I sign in to driver? A DIY on how to replace the o-ring. =D
Thanks for the great write up and pictures. Really informative and helps a newbie like me a lot.
Old 04-18-2013, 12:45 PM
Zioxx's Avatar
No leaks on my car yet but seems like something ill be doing on my next oil change.
Great write up.
Quick Reply: DIY : Oil Cooler O-ring Replacement V35
