i really need help!!!!! g35 infiniti
Old Apr 1, 2013 | 11:58 PM
Jerzee10's Avatar
Exclamation i really need help!!!!! g35 infiniti
Recently i got my tires changed and my wheels but i'm not sure if that has anything to do with it.
Well, i started driving this morning and when i put it into first gear i started putting gas on the pedal but been having low speed and HIGH Rpms upon starting. the speed was going up slowly but the RPM was already going to 6 RPM so i switched to second gear and it kinda stayed around 5-6 RPM. Than it finally started to drive normal but in the beginning it takes a while to start driving and it's getting worse. Also, i might add... When i step out my car i smell like a little bit of burning i'm not sure what that could be.. any suggestions or thoughts would really help i'm taking it to the shop soon but was wondering if my fellow G lovers could help
Old Apr 2, 2013 | 12:05 AM
TheDizzle's Avatar
Clutch is gone. Replace
Old Apr 2, 2013 | 05:45 PM
Jerzee10's Avatar
i mean for now it's still drivable but could it be that i need clutch fluid?
btw... Nice G on your Avi
Old Apr 2, 2013 | 06:02 PM
GR6RR's Avatar
clutch is going out... you will get stranded somewhere if you don't fix asap.
Old Apr 2, 2013 | 08:47 PM
N8Deezy's Avatar
^^ same as the other 2 comments. get that taken care of ASAP. even if you had dirty fluid and did a change that's only a band-aid if that.
Old Apr 2, 2013 | 11:25 PM
Jerzee10's Avatar
thanks everyone i appreciate your help, Tomorrow i'm taking it to the Shop and getting a new clutch.. But now i'm Wondering what kind of clutch should i get and how much money is it going to cost me? i only have 1200$ in my bank account.
Old Apr 2, 2013 | 11:32 PM
N8Deezy's Avatar
You can definitely get it done for cheaper than $1200. Especially if its only the clutch. Not sure what you're looking for whether its an oem replacement or a performance clutch.
Old Apr 2, 2013 | 11:50 PM
Jerzee10's Avatar
Well i never had to deal with a bad clutch because this is my first G and my second car with stick. Therefore, i'm not sure which is better but i'm actually going to look into it now.
Some advice from our fellow G lovers, would be greatly appreciated.
Old Apr 3, 2013 | 07:22 PM
LolMooses's Avatar
I put an Exedy NSK1000 OEM replacement clutch and it's been great so far. I've had it for over 3000 miles now without a problem. They go for around 250 last I checked.
Old Apr 4, 2013 | 03:16 AM
Tolboothwilley™'s Avatar
lots of options available...do a little research on the forum here before you buy
I like the JWT flywheel/clutch combo
a little chatter is all
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
