Drive belts
Old Apr 15, 2013 | 09:52 AM
Sean13's Avatar
Drive belts
Just changed the drive belt yesterday and this morning when i started the car. It made a very loud squeaky noise, but gone after a few second. Is it because the belt is too tight?
Old Apr 15, 2013 | 10:19 AM
R.J.'s Avatar
It may not be tight enough. Just changed my belts as well and from what I read you may need to tighten them up in order for the squeal to go away. I am going to be trying that this evening.
Old Apr 15, 2013 | 12:19 PM
P10 WRC's Avatar
usually means too loose.
Old Apr 15, 2013 | 01:22 PM
gary c's Avatar
Squeeks in a new belt indicate it's too lose, a fraction tighter should keep it quiet....Gary
Old Apr 16, 2013 | 09:53 PM
cvipgo's Avatar
It could be you have bad idler pulleys
Old Apr 17, 2013 | 03:10 AM
GTX915's Avatar
I have the same problem...changed belts because of squeak, afterwards my belts still squeak. Tightened everything, could it be the pulleys? ^^
Old Apr 17, 2013 | 06:59 PM
Sean13's Avatar
Just tighten mine up today...we'll see if it still squealing tomorrow morning
Old Apr 17, 2013 | 07:01 PM
hurleyguys's Avatar
usually if it is still squeaking after doing your belts means prob not tight enough or one of ur pulleys are bad.
Old Apr 17, 2013 | 07:17 PM
cvipgo's Avatar
I had same problem and I replaced pulley and all squeaking gone. Replace your 2 idler pulley.
Old Apr 17, 2013 | 08:34 PM
gary c's Avatar
Lets assume his belts were not making noise before he replaced them. Now they've been replaced, they're making noise. How could it be anything else but they're not tight enough? Only consider blaming the idler pulley if he had noise before belts were replaced and the new belts were installed correctly!
Gary
Old Apr 17, 2013 | 08:58 PM
cvipgo's Avatar
New belts are tighter and the play in old worn out idler pulley are the cause of the noise.
Old belts and old pulley may not make noise due to slack in the belt and do not force the metal to metal grind.
I have gone though this on my 03 g35 with 120k miles- I had cracked belts so I put new belts, installed correctly and idler pulleys started screeching, I replaced the 2 idler pulleys and all noise disappeared. Idler pulley are not that expensive and replacing them is good for other pulley driven units e.g. water pump, alternator, compressor etc. having bad idler pulleys can lead to serious problems with water pump, alternator, compressor etc.
Old Apr 17, 2013 | 10:04 PM
1V8ADAY's Avatar
Well said @cvipgo. I bought my car with a whinning (sounded like a Ford p/s pump). I bought all of my freshen up stuff, belts, plugs and the passenger tensioner. No more whinning.
New belts will make older tensioners/idlers squeal
Old Apr 18, 2013 | 02:48 AM
GTX915's Avatar
How much did you end up paying for the pulleys man?
Old Apr 18, 2013 | 09:38 AM
cvipgo's Avatar
about $100
Old Apr 18, 2013 | 02:32 PM
Sean13's Avatar
No more noise this morning for me..!!
