NEED HELP! Oil Pan Gasket Leaking?
Old Apr 17, 2013 | 11:59 PM
nicoG35's Avatar
I need help! I don't know much about cars, but I got my oil changed today and they said the oil pan gasket on my 2004 Infiniti G35 Coupe is leaking, and some automotive shops are saying it's a 10 hour job, and it's going to cost around $750 for just labor. Is this true?! Ugh!
Is there any other way to fix it?
Thanks in advance!
Old Apr 18, 2013 | 12:06 AM
herrschaft's Avatar
First, verify yourself that its actually leaking. I had a shop install a different oil pan which essentially is the same procedure as replacing the gasket, I believe they charged me less than $100 and took them no more than 2 hours. Unless the gasket is for your upper pan which I can't imagine would be much worse.
Old Apr 18, 2013 | 12:26 AM
nicoG35's Avatar
Thanks! I'll check!
Old Apr 18, 2013 | 11:36 AM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
Considering there isn't a oil pan gasket on these cars, I would have an actual shop investigate it, not a quick lube place.... the Oil Cooler O-Ring is often the problem, very rare that it would be the upper pan gaskets, but I don't think it's a 10 hour job regardless....
Old Apr 18, 2013 | 12:34 PM
nicoG35's Avatar
Thank you so much Phil! I will definitely have shops diagnose it!
seagrasser
May 3, 2022 09:43 AM
alessandro
Oct 8, 2015 09:29 AM
hrdwirk1
Oct 2, 2015 06:34 PM
yosip1115
16
Sep 28, 2015 04:14 PM
UT G35
Sep 3, 2015 03:58 PM
