help, stuck on side of the road
Old May 15, 2013 | 09:02 PM
teahead's Avatar
threw a belt, but looks like this tensioner froze up.
easy to replace? that isn't the water pump is it?
Old May 15, 2013 | 10:08 PM
ItsA..Gthing's Avatar
Not hard to replace...
Old May 15, 2013 | 10:18 PM
HenryLee's Avatar
^ Not hard to replace but Damn! What year and miles is your car? Good thing I replaced both of my belts today. Its an easy job, the hardest part was getting the bottom plastic cover off.
Old May 16, 2013 | 11:19 AM
eZg's Avatar
eZg
Isn't there a DIY on a delete for that pulley? swore I've seen one either here or my350z.com
Old May 16, 2013 | 11:27 AM
superchargedg's Avatar
Thats just the idler pulley and is pretty easy to replace.
Old May 16, 2013 | 11:42 AM
teahead's Avatar
Okay, do you just remove that bolt that bolts the idler pulley on? or do you remove that whole bracket that's bolted to the block?
Car only has 74k on it, and I think less than 50k on the motor (previous owner had it replaced due to hydrolocked).
Does this idler pulley typically create problems? Hence why it gets deleted?
Old May 16, 2013 | 11:47 AM
SergeantRed's Avatar
Sorry don't know of a DYI but lucky for us you should be able to remove the timing case cover without dropping the engine. It's a tight space but not impossible just a PITA
Old May 16, 2013 | 12:31 PM
teahead's Avatar
Hmm...looks like I may just cut that thing off and not go w/an idler pulley like these guys:
http://my350z.com/forum/engine-drive...th-pics-4.html
Although I don't understand what the "spacer" is for.
Old May 16, 2013 | 12:49 PM
eZg's Avatar
eZg
I think it's cause the bracket itself is already serving as a spacer so you can't just leave it off.
Old May 16, 2013 | 02:10 PM
teahead's Avatar
Something is odd. I think i have a Stillen Supercharger bracket w/the pulley on there as it looks nothing like what others have.
Old May 16, 2013 | 02:35 PM
teahead's Avatar
Ya, this looks like a Stillen-supplied bracket alright. Dang it!
Old May 16, 2013 | 03:35 PM
It is just a unbolt and replace part
R350k5
Oct 1, 2015 08:41 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
ev_g35
Interior
Aug 14, 2015 02:05 PM
Nick_M
Aug 3, 2015 11:08 PM
itschuckster
Jul 25, 2015 08:07 AM
