NWP 75mm throttle body review
Old Aug 29, 2013 | 09:51 AM
GreenGoblin's Avatar
The goblin resurrection
yes you would be able to eliminate the copper piece, as long as the tubing is the same size.
Old Aug 29, 2013 | 12:56 PM
LoSt180's Avatar
Originally Posted by herrschaft
^More than likely he removed them from the original TB since you really don't need to run coolant through there. The NWP TB has the coolant pipes attached.
The original coolant lines run through the upper plenum, not the TB. The NWP TB is really the OEM 09+ Maxima TB and the coolant lines are integrated since the Maxima runs a plastic intake plenum.
Originally Posted by G_DiRTY5
Ah okay so that would mean I wouldn't need the copper piece that came with my plenum spacer kit.
In theory yes you wouldn't need the copper piece anymore. Only problem I can think of is getting the hoses to line up with how the NWP tubes are aimed, they look pointed in different directions to me.
I'm assuming you're referring to the valve, its not required to have that piece installed. ...
/snip
The valve and the copper piece he's asking about are two different things. The copper replaces the need for that valve. You've been here long enough to know better...
Old Aug 29, 2013 | 04:20 PM
herrschaft's Avatar
Good catch
Sorry, but I don't follow every version of the spacer kits MD offers. I bought mine almost 3 years ago and it came with a valve. Maybe if people could be more descriptive when they post, any confusion can be avoided.
Old Aug 29, 2013 | 04:45 PM
herrschaft's Avatar
Originally Posted by GreenGoblin
Did you happen to notice any slight changes in the AFR?
Old Aug 31, 2013 | 01:32 AM
I am running a haltech with the dual wideband so it is set up to hit a target afr, one of the things I need to do is see if with that compensation off if it leans it out some. I have been working like a man man, I need to get it on the dyno asap.
Old Nov 6, 2014 | 03:41 PM
Exodus5656's Avatar
I actually looked for a larger throttle body last night while looking for a replacement boot. I am happy to see this. I am curious though to know a few things about these dyno runs.
1.What other mods do you have?
2.Where did you find a Cosworth CF Intake Manifold?
3.Do you know or have any dyno test with the rev up motor?
I look forward to possibly getting this and adding it to my list of "breather" mods. Thanks for bringing this up on the threads!!
Old Jan 30, 2015 | 12:04 AM
G35thrilla's Avatar
What is needed exactly to make this TB work. Is the piping that's needed the furookie 3.5? Also will the original maf sensor fit and perform properly in the furookie since not it's sitting at a diff dept within the piping? Of does that have to get changes also?
Old Jan 30, 2015 | 05:11 AM
scottvt's Avatar
Order the kit from NWP and they give everything you need to make it work. I ran mine with the 3" Furookie until I found a 3.5" Furookie. No dyno numbers but didn't notice much a difference. And your stock MAF will be fine, assuming your mods don't require a "larger" sensor. It still sticks in the tube the same depth, just the diameter of the tube is larger, you will probably want some tuning done though after the install.
Old Jan 30, 2015 | 10:51 AM
TheJuice401's Avatar
would the nwp deff have some effects if you go turbo or sc? ive read alot of threads and still dont see how this does any type of gain... like somebody said before, its like adding a tiny piece of wider straw to the middle..
Old Jan 30, 2015 | 01:45 PM
Exodus5656's Avatar
That is a good analogy and from what I see to maximize gains from this throttle body you would need full exhaust and full intake. That includes valve work. You would also get more out of it if you did fuel system work too. Mods are like a math problem, meaning everything has to balance from the intake side to the exhaust or you won't get your moneys worth from it.
Old Jan 30, 2015 | 07:30 PM
G35thrilla's Avatar
Ya I read a bunch of reviews on my350z last night. And came across one where the op had it dynoed and gain a solid 1 whp. Solo deff not worth the money imo
Old Jan 31, 2015 | 10:45 AM
PhoenixG35's Avatar
yes, but what were the gains throughout the powerband? even NWP's dyno sheet shows peak power loss.
Old Jan 31, 2015 | 11:05 AM
G35thrilla's Avatar
No supposedly they where towards the claimed gain on the high end. I dunno they 350z forums all seems to point to the fact that the gains are no where close to what is shown on the nwp dyno sheets. And these are on rides with full bolt on mods
Old Feb 1, 2015 | 02:17 PM
Jairen's Avatar
I have it and no gains were felt. Better off spending money elsewhere such as a lightweight driveshaft.
Old Feb 1, 2015 | 02:28 PM
  #30
that what i was learning towards next! i did some research but wasnt 100% clear if the carbon fiber one is even worth it.
also is there any cons to having a one piece driveshaft? and will it handle 400whp? thanks!
