1.6k rpm when idling
Old Dec 10, 2013 | 05:19 PM
JEAThirty5's Avatar
I have a 2005 G35 Sedan. only thing not stock is K&N AF and LED bulbs. almost 108k miles. Always pumped shell 93 and this is the first problem I have faced with my car
I went on vacation and left my car at the airport for 5 days. When i got back i immediately noticed the car pulling a little harder when accelerating and when i was braking.
Now my symptoms are when i am in drive and off the gas engine creeps up to 1.6k rpm. It'll even shift to second gear and creep up again to 1.6k.
One fellow said i'd have to replace my throttle body, a friend said idler valve may be stuck, and another friend said the TB may just need a cleaning.
I've had 3 different opinions and wanted to see if anyone on the forums had a similar problem/solution or can confirm if any of these are the solution before i have any work done.
TIA,
JEAT
When i am at a complete stop and in drive and on the brake car idles normally @ ~800rpm
Old Dec 10, 2013 | 05:36 PM
Urbanengineer's Avatar
Clean tb
Old Dec 10, 2013 | 08:47 PM
JEAThirty5's Avatar
Alright i will do that and let you know how it goes thank you
Thebaws11
Jul 2, 2021 11:36 AM
vamarris
Sep 26, 2015 12:56 PM
sullivan72
Sep 22, 2015 11:39 PM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
Jnm07
Sep 5, 2015 01:16 AM
