G35S - How can I advance ignition Timing
Old May 5, 2003 | 08:31 AM
UncleAl's Avatar
Is this a non adjustment? Perhaps controlled by ECU? Would like to advance timing for better low end performance.
If anyone has the service manual, I'd appreciate knowing how to advance the timing.
Thanks
Uncle Al
Old May 5, 2003 | 10:40 AM
ryoken's Avatar
Re: G35S - How can I advance ignition Timing
This is something a "chip" mod would do.. a programmable ECU. The ECU controls the timing. I haven't seen one out for our cars yet. Maybe someone else has?
Old May 7, 2003 | 11:00 PM
QuadCam's Avatar
just twist the distributor. just kidding. you'll have to go the electronic route. the problem is most chips are a waste of time on a naturally aspirated car. the modest gains that you'd get from advancing your distributor were great because they were free mods. to pay several hundreds of dollars for a chip that gives you the same meager gains is tough to swallow.
Old May 8, 2003 | 07:20 AM
GIlovemycar's Avatar
You can't adjust the timing or at least advance it. I talked to my tech on tuesday he is looking in to what if anything he can do. But it is not looking promising
Old May 11, 2003 | 12:25 AM
envykillz's Avatar
not true, an NA 3 series can gain up to 45 - 50 hp to the wheels from a variable timing chip mod
Old May 11, 2003 | 10:29 AM
johnzg35's Avatar
Check with your service adviser whether it can be adjusted with the Consult-II.
chinee
Jun 10, 2024 07:48 PM
rezendvous420
May 31, 2020 01:26 PM
wojowojo16
Jul 27, 2015 09:57 AM
laksjd84
Jul 24, 2015 05:12 PM
quickspeed6
24
Jul 15, 2015 11:06 AM
