What makes a car do this?
Old Aug 20, 2014 | 04:15 PM
coffeysm's Avatar
Originally Posted by ACE420
Haven't cleaned my MAF yet. I'm going to install new headers on Friday so I can just swap the sensors well I'm there I guess. But I'm thinking (correct me if I'm wrong) if it threw both sensors codes at me for upstream and now after fixing some thing with the plenum it only shows 1 code now do you think it related to another leak somewhere? Also yea car use to run at 1100-1300 rpms before I installed new spark plugs and it went down right below 1000 rpms. Also when A/C is on periodically my rpms climb to about 1000 then drops to about 400 over and over then stops out of no where and A/C blows cold air again normally
It's possible there is still a vacuum leak somewhere. Only way to be sure without the obvious is to do a smoke test. They're expensive though, but I made my own out of small paint can and 20 dollars in parts, lol.
Try unplugging the MAF, monitor the fuel trims, and it should run extremely rich. If you know somebody with a G, Maxima, 350Z, or similar engine try to see if you can borrow their MAF to see how it runs. The MAFs can go bad, but you wouldn't know it. I'd at least clean your MAF first.
I'd stick some fuel system cleaner in there as well BG44K works great.
Your idle speed is way to high, I think it should be at 650 +-50. You're not getting a P0507 error about it being that high?
Oh yea, I think if you have Berks HFC you don't need the foulers they're built-in. So, I don't think that would be an issue now and since it's only oneside.
I'd swap the O2 sensors when you have the headers off.
Old Aug 20, 2014 | 04:29 PM
ACE420's Avatar
Ok I will try that next then! Thank for your help I really appreciate it a lot! I'll update soon
Old Aug 20, 2014 | 09:13 PM
ACE420's Avatar
Just cleaned MAF and it didn't do anything. My AC sounds like it's trying to kick on I can hear the click in engine bay and then cuts off and starts all over again it happens a lot
Old Aug 20, 2014 | 10:20 PM
coffeysm's Avatar
Maybe your AC is low on refrigerant? I'd wait till Friday then and swap the sensors and see if the code moves. No sense trying to throw parts at it.
Old Aug 20, 2014 | 11:37 PM
ACE420's Avatar
Yea I recharged the AC a few weeks ago so I'm hoping it's not that lol then it would be an AC leak now. But yea I'm going to wait till Friday! Hopefully all goes well with the install! I'm anxious and scared but after I'm done it should be a great feeling of accomplishment
Old Aug 21, 2014 | 01:51 AM
coffeysm's Avatar
Yea, that sucks. So, your idle is still that high with the AC off?
Old Aug 21, 2014 | 01:23 PM
ACE420's Avatar
That's with the AC on....the noise seems to stop making that clicking noise like it's trying to kick on or something but keeps getting cut off. And idle seems to get a lil better with AC off though..maybe the coolant lines need to be "burped"..I'm going to be draining with header install so I guess we will see tomorrow
Old Aug 21, 2014 | 11:27 PM
ACE420's Avatar
Also where did you buy the clamps for the bigger aftermarket hoses?
Old Aug 21, 2014 | 11:38 PM
coffeysm's Avatar
I just went to harbor freight and bought a huge selection of different size clamps. The correct ones were ridicously expensive.
If you're not having overheating issues I don't think you need to bleed the system. I'd check the pressure of your ac system or get one of those UV kits.
I think you probably should try to do an idle relaern if you're. It around 650+- 50 with the ac off.
Old Aug 21, 2014 | 11:51 PM
ACE420's Avatar
Ok thanks man! I appreciate it
rezendvous420
May 31, 2020 01:26 PM
NemesisGee
Aug 11, 2015 07:10 PM
ClwMike
Jul 23, 2015 12:55 PM
Karnicle
Jul 23, 2015 05:08 AM
stay_tuned
Jul 21, 2015 07:09 PM
