Bad Rumbling and Shifter Off Center
Old Apr 8, 2015 | 02:59 PM
Loelife's Avatar
Hi all,
I recently picked up an 04 MT Coupe with 84k. Owner said the rumble is from the Flywheel getting used to the (new)clutch.. (never heard of that. ever.) I've tried to rule out different circumstances by putting it through a couple of tests. here's what I've found:
open throttle in neutral: fine
open throttle in 1,2 and a bit of 3: rumbling BAD
open throttle in 4-6: fine
light throttle in 1-6: Ok
so confused. Ive never owned one of these but I do have wrenching experience. Would anybody be able to chime in? Anything helps.
thanks,
Gabe
Old Apr 8, 2015 | 03:17 PM
yosip1115's Avatar
Odd, I don't really know what this "rumble" sounds like but I would check to see that there is a bolt going through the tranny mount and that it is not just hanging out in the X member, that would cause the shifter to be off center towards the rear. What direction is it off center towards?
Old Apr 8, 2015 | 03:35 PM
Loelife's Avatar
leaning to the right. I'll try to get a video and post it later. Also, When I open up the throttle all the way, The shifter wants to move. Its odd.
by the way, thanks for the quick response!
Old Apr 8, 2015 | 04:22 PM
yosip1115's Avatar
It could also be a bad engine mount. I'm sure that if one of us guys that have been around these cars for years looked at it they would see what was wrong in five seconds, or maybe that isn't the case. None the less this is an interesting issue.
When you are taking a video pop the hood and rev it while looking between the hood and hood cowl with the camera to see if the engine moves any more than normal...
Old Apr 8, 2015 | 04:42 PM
Loelife's Avatar
Thanks for the advice! I'm about to get off of work. I'll take a driving video right now then I sitting one one I get home.
I'm located in Sacramento, CA so if anybody wants to meet up I'm open to that! I'd really appreciate it.
Old Apr 8, 2015 | 10:00 PM
Loelife's Avatar
http://youtu.be/7M6sugC8GLc
Here's the video. I accidentally said neutral instead of reverse lol. You'll see
Old Apr 9, 2015 | 08:19 AM
yosip1115's Avatar
Holy **** man, they F'd something up. You can probably tell if the passenger side engine mount blew out by just shaking the motor with both hands, the car suspension should move before the engine does inside the car. Right now that's my best guess and it makes sense that it is only when you mash it that it starts to rumble, that could be the engine being torqued against the firewall. By driving you could make it worse or even break a manifold stud, be easy until you find the problem. Looks nice out there in Cali... Damn.
Old Apr 9, 2015 | 11:37 AM
Loelife's Avatar
Damnit. I was thinking I could be a mount as well. That sucks. I won't be able to fix until the weekend so hopefully nothing gets ruined by then.
Old Apr 9, 2015 | 11:44 AM
yosip1115's Avatar
ehh don't sweat it, they may have just forgotten to re-fasten a bolt or something like that. Keep us updated...
Old Apr 9, 2015 | 04:59 PM
adeedpb's Avatar
I live in the Sacramento area if you ever need some help.
Old Apr 9, 2015 | 11:57 PM
Loelife's Avatar
So Ya I'm gonna try to void this sale. That guys was bullshittin hardcore.
That's not slotted anymore
Old Apr 10, 2015 | 02:05 AM
Loelife's Avatar
Did some Research.
Don't think I can void the sale so that sucks. Guess I gotta look into getting the crossmember replaced
Old Apr 10, 2015 | 06:34 AM
yosip1115's Avatar
I don't recognize that part from so close up, is it the tranny x member or the front suspension x member? Damn!
Old Apr 10, 2015 | 10:44 AM
Loelife's Avatar
That's the crossmember for the front suspension. Where the torque mount is
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
EasySausage
Sep 24, 2015 01:06 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
gatorglaze
Sep 10, 2015 12:03 PM
n2fooz
Sep 4, 2015 07:46 PM
