Oil Leak ON MY 03 G35 SEDAN
Old Aug 29, 2015 | 05:12 PM
murphd3rf's Avatar
Recently Changed:
my valve covers and gaskets/grommets
rear main seal
oil change
after changing all that, it seems to be still leaking.
whatelse could cause an oil leak?
just wondering.
Old Aug 29, 2015 | 07:25 PM
knightro g35's Avatar
Well clean the engine good and find where it is coming from.?
Is it leaving a puddle of oil after you sit a while?
Old Aug 29, 2015 | 09:13 PM
murphd3rf's Avatar
yes it is.
Old Aug 29, 2015 | 09:46 PM
Should be noticeable where it is coming from just get a flashlight and start looking
Old Aug 29, 2015 | 10:49 PM
murphd3rf's Avatar
i might have to pressure wash the **** out my engine to find out.
Old Aug 30, 2015 | 12:10 AM
Be real careful around electronics, wires and the intake.
Old Aug 30, 2015 | 12:13 AM
murphd3rf's Avatar
okay thanks, ill probably get it steam washed probably. depends
Old Aug 30, 2015 | 01:15 AM
Hotdawwgman's Avatar
I had a small oil leak around the oil cooler… That's where the oil filter screws onto… I also had a small leak on the lower oil pan… Took care of them and it's been good since
Old Sep 1, 2015 | 06:38 PM
murphd3rf's Avatar
How did u fix it?
Old Sep 1, 2015 | 08:21 PM
saywat?'s Avatar
this is the only pic i could find even tho its not for the g35 the seals are the same places
i recently had my rear main seal replaced as well. the oil pan gasket (2x) is a hidden source for leaks at well #1 &4 in pic. my front one has a tiny leak (oil vapors). front crank seal could be source of leak as well. debating to get it done or wait till it gets worse cus its a big job like the rear main seal
Old Oct 5, 2015 | 02:51 PM
hgoodwiniii's Avatar
Hi all, how tough is it to replace upper oil pan gasket and rear main seals on a 2004 G35Sedan?
The lower oil pan gasket, oil cooler seal and valve cover gaskets have all been changed recently.
The current leak is coming from the rear side of the engine that is closest to the transmission. I'm assuming it's probably the rear seal that is described in this thread.
Old Oct 5, 2015 | 02:55 PM
saywat?'s Avatar
its a pretty big job . i wouldnt do it esp if ur jus a backyard mech with no lift. the trans has to be removed
Old Oct 6, 2015 | 01:10 AM
Oh wow; I didnt realize the tranny had to come out. Thanks.
Old Oct 7, 2015 | 12:12 PM
Hi saywat?, who were you able to get to change your seals and oil pan gasket? I can't seem to find anyone in the Houston area besides the Infiniti dealership.
Old Oct 7, 2015 | 01:33 PM
saywat?'s Avatar
I took it to a friends shop. I'd think any experienced shop can do it. If u need a new clutch this would be a good time to throw it in while the trans is out
