Lightweight Flywheel Question
Old Jan 16, 2019 | 11:26 AM
jdw3996's Avatar
2004 G35 Sedan
When I’m sitting at idle in neutral I hear a metallic vibration like noise. If I push in the clutch it goes away. Is this caused from a lightweight flywheel? I was told by the previous owner that it has one, and I get the metallic bag of bolts rattling noise at low rpms in 1st so I’m sure he wasn’t lying.
Old Jan 16, 2019 | 01:51 PM
MooseLucifer's Avatar
5 Year Member
blk
Bad news - a metallic noise when the clutch is engaged means your pilot bushing is going out. Some folks opt for the Nismo needle bearing upgrade when they install a lightweight flywheel, and I've heard that they tend to fail prematurely.
I can't exactly blame Nismo for that, as in this case Nismo = racecar = willing to tear down and rebuild more often.
Old Jan 16, 2019 | 10:11 PM
cswlightning's Avatar
^^^ He is saying it makes the noise when he's not pressing in the clutch. It's really quiet when stock, and gets much louder when you install a lightweight flywheel. It's normal.
Iron_Man
Feb 9, 2007 09:21 PM
rlwjr1
Drivetrain
11
Dec 29, 2006 01:38 PM
Purcha
Aug 30, 2006 02:40 PM
futbol333
Aug 22, 2005 06:02 PM
shooter
Drivetrain
21
May 19, 2005 05:54 PM
