Help! Slave not engaging clutch fork after replacing
Old Feb 17, 2019 | 09:49 AM
cswlightning's Avatar
Changed clutch and flywheel, now my clutch pedal goes to the floor without actually putting pressure on the pressure plate... The fork moves freely for the clutches full travel. I haven't tried anything yet to fix given I finished last night very late, but anyone have ideas that doesn't involve dropping the tyranny again? What went wrong? I never opened the clutch hydraulic system. Need to fix before Tuesday!
Old Feb 17, 2019 | 10:07 AM
I should clarify that the clutch does disengage but past the point where the pedal is hitting the floor, you have to manually move the fork. Are clutch cylinder spacers a thing? I'm thinking I might have to machine something that adds an inch to the slave's length...
I changed the TOB and clutch ball and I'm 99.99 sure it's all seated properly... Engine starts and revs fine in N
Old Feb 17, 2019 | 11:57 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The clutch fork shouldn't be able to be actuated by hand, there should he so much pressure on it from the clutch pressure plate that you can't move it without basically putting your entire body weight against it.
You're sure it was seated into the rocker ball thing inside the transmission housing? And I'm not sure it's even possible to do this wrong but the TO bearing didn't get installed backwards did it?
Old Feb 17, 2019 | 11:58 AM
cleric670's Avatar
BANNED!!!
I would DEFINITELY try to bleed the slave cylinder though.
Old Feb 17, 2019 | 03:03 PM
As usual I ran to the forums too soon. just had to adjust the clutch pedal a bunch and it's perfect now.
The new assembly must be different in length for some reason, the difference between old worn components and new..?
Turns out the old pressure plate was an ACT HD which I would have reused if my new oem z1 mild clutch and flywheel weren't already machine balanced as a unit
Old Feb 19, 2019 | 10:49 AM
MooseLucifer's Avatar
5 Year Member
blk
Not sure why it happens, but that happened both times I've changed clutches on a G as well.
Regardless, sounds like you already learned that you have to adjust the pedal all the way back (master cylinder piston fully retracted vs pedal) before you bleed, then when you're done bleeding readjust the pedal to wherever you prefer.
Old Feb 19, 2019 | 01:04 PM
I never even bled it, just took the bolts out and moved the SC to the side while doing the install. PO already installed an aftermarket cylinder and SS clutch line so I'm good there. Clutch feels fine, not sure that I want to bleed it and risk messing something up when everything working great.
sean_t0
Sep 17, 2023 10:57 AM
G35Bandit
Drivetrain
Nov 26, 2016 05:57 PM
TheBay
Sep 3, 2015 08:25 AM
Decode
Feb 6, 2012 09:49 PM
y.dan
Drivetrain
30
Apr 5, 2006 01:58 PM
