Getting a P0420 code?
Old Apr 13, 2019 | 01:18 PM
Hersh1995's Avatar
2004 G35 coupe 6MT
Getting a P0420 code. I know it means CC is below threshold, how do I tell if it's bad CC or o2 sensor. Also, could it be other things causing it?
Old Apr 13, 2019 | 07:58 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
420 dude.
Pull your spark plugs and check them, also check for any intake leaks. OBD2 scan for LTFT threshold and if it's above 15% you've almost certainly got a vacuum leak, smoke test the exhaust for leaks.
If everything looks good you might have a catalytic converter starting to **** the bed.
Old Oct 29, 2024 | 04:50 PM
finnessser's Avatar
G37 Sport
420 dude.
Ive got P420 Bank 1 and P2A03 Bank 2 Sensor 1 coming at me. Replaced the Bank 2 Sensor 1, O2 sensor already. Got a passenger side air duct coming in because I found that it was cracked. Will check for more intake leaks, found an exhaust leak after the O2 sensors, but currently Im scratching my head on how to fix this
G35 NL
Mar 17, 2022 09:28 AM
El_Donks
Intake & Exhaust
Mar 6, 2022 12:22 PM
alexbeau
Feb 12, 2018 02:50 PM
LowUFO
Apr 5, 2011 12:37 AM
officerdbag
Feb 14, 2010 10:54 PM
