engaging the clutch stalls the engine
Old May 18, 2019 | 07:27 PM
El Angelito's Avatar
Infiniti G35
Exclamation engaging the clutch stalls the engine
Hey guys, I'm wondering if you guys could help me out with something. I have a 2004 G35 coupe and whenever it's idling at running temperature and I engage the clutch the car stutters and dies or stalls. I replace the spark plugs on it and all the cam and crankshaft sensors, I can't seem to find the problem and recently it started overheating when I would drive it. if any of yall have suggestions or ideas to fix this I would appreciate it.
Old May 18, 2019 | 10:52 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Are you giving it gas when you release the clutch?
Jack up the car and spin all the tires to make sure you don't have a brake caliper seized up.
Overheating problem, check coolant levels. If they look good then pressure test the system, including the cap, if it can't build pressure it will overheat eventually.
Old May 19, 2019 | 02:08 PM
Infiniti G35
I already checked all of that, and a car shouldn't die just by putting in the clutch. I'm not putting it in gear or anything in just pushing the pedal down and it dies. and when I'm driving down the road and I press the clutch the car dies.
Old May 19, 2019 | 02:56 PM
cleric670's Avatar
BANNED!!!
Ohhh when you DISENGAGE the clutch it dies. Probably a bad idle algorithm.
Perform the idle air recalibration.
https://nicoclub.com/archives/g35-35...procedure.html
Old May 19, 2019 | 04:18 PM
telcoman's Avatar
Veteran: Army
Or a defective clutch interlock switch?
Telcoman
Old May 19, 2019 | 04:22 PM
cleric670's Avatar
BANNED!!!
Wouldn't the switch just prevent the cruise control from working?
Old May 19, 2019 | 08:07 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
So maybe that's why my cruise control isn't working? Light comes on to show the system is on but it won't set speed.
Old May 19, 2019 | 08:28 PM
cleric670's Avatar
BANNED!!!
Yeah check the switch at the top of the clutch pedal.
Old May 22, 2019 | 03:22 PM
Infiniti G35
Unhappy
I did the idle recalibration procedure and it still has the problem of staying alive during idle. if it's at running temperature it struggles to stay alive but if I disengage the clutch it losses revs and sometimes it will still stay running but then other times it dies. does anyone else have an idea to what this might be? Oh, and I already smoked tested it so there are no leaks in the vacuum system.
sean_t0
Sep 17, 2023 10:57 AM
PLNG35
Jun 11, 2013 01:20 PM
denav35cpe
Mar 15, 2012 10:01 PM
ramo
Oct 5, 2007 07:11 PM
