Wont start or turn over. New battery cam crank and knock senors and knock sensor harn
Old Aug 29, 2019 | 02:41 PM
Josh Sanchez's Avatar
base model. Leather seats.
I have a g35 sedan automatic base model. My car wont start or turn over when the key is turned. I got a brand new battery that is fully charger and good to go, got it tested and its good. At first while i was driving a few dash lights came on and i lost power and it wouldnt accelerate. Its been sitting for a few months and Now it wont start or turn the engine over at all. B4 it would atleast start. I installed new crank sensor and both cam shaft sensors. Along with the knock sensor and knock sensor harness. And bought a new battery thats 100%. The dash lights up when i turn the key and everything works but when i fully turn the key to start the car the dash lights turn off and it makes 1 click then does nothing. But when i release the key the dash lights come back on. The key fob works perfect and the alarm comes on when i press the panic button. I've open and locked the door with just the key and still nothing. Im completely out of idea's and could really use some help. Thank you
Old Aug 30, 2019 | 04:37 AM
Scorpi0's Avatar
Hopefully your engine isnt seized. But just to rule out a defective battery, I would try jump starting it from another car first. Its not that uncommon to get a brand new battery from the store thats defective.
If battery is confirmed good: Check the starter with a multimeter and see if its getting power when u turn the key.
Old Aug 30, 2019 | 07:23 AM
Tried jump starting it and it does the same thing. Nothing happens. Im gonna check out the starter today. Thx
Old Aug 30, 2019 | 07:24 AM
I had the battery tested and they said its 100% and fully charged
Old Aug 30, 2019 | 09:19 AM
telcoman's Avatar
Veteran: Army
Have you referenced the FSM?
https://nicoclub.com/FSM/G35/Sedan/2008/STR.pdf
Telcoman
Old Aug 30, 2019 | 09:56 AM
Nope havent looked into that yet. Thank you for the link, i will go through the steps and hopefully it helps.
Old Aug 30, 2019 | 09:57 AM
The enginr isn't seized up. It turns over by hand no problem
Old Aug 30, 2019 | 12:07 PM
Scorpi0's Avatar
If the starter is getting power but isnt turning, then thats gonna be your problem.
Old Aug 30, 2019 | 12:29 PM
I just got the starter removed and taking it now to get it tested. Will post my results. Thank you everyone 🤘👍👍
Old Aug 31, 2019 | 01:02 PM
The manager at the auto parts store went to hook up my starter on the test bench and she hooked it up wrong and it poped and started smoking so she gave me a new one. Just got it installed and the power wire that has the plastic around it was full of water so im heading to get some wire and connectors to run a new positive wire from the battery.
Old Sep 1, 2019 | 04:57 AM
Scorpi0's Avatar
Uhhh what??
Old Sep 1, 2019 | 01:12 PM
After running a new power wire to the starter the car started right up. But its still throwing the the slip and vdc off light are still on even after changing the knock sensor and harness. Idk what else to do. Any thoughts?
Old Sep 1, 2019 | 01:28 PM
When i first start the car the vdc and slip lights aren't on but when i hit the gas to speed up they both come on and the car wont accelerate.
sherwood87
Jul 10, 2018 10:23 PM
needhelp1
Jan 17, 2018 11:56 AM
Fernando Lopez
Oct 6, 2012 06:40 PM
jmoe71
Oct 1, 2010 12:45 AM
langeg35
May 15, 2009 02:20 PM
