2009 Ex-35 Check Engine Sign, VDC OFF, Slip Indicator Light !!
Old Sep 19, 2019 | 01:59 PM
Sabrina Bhatti's Avatar
EX-35
Exclamation 2009 Ex-35 Check Engine Sign, VDC OFF, Slip Indicator Light !!
Hi there I have a 2009 Ex-35, the car was past due for oil change/maintenance. Yesterday, I noticed that the Check Engine Sign, VDC OFF and Slip indicator all turned on while I was on the high way. I was not able to excellerate as the car would jerk, I put it into the sport/manual mode and was able to get home but it seems to not be changing gears. I got the oil changed and all the fluid levels checked today. They did mention my oil was very dirty and cleaned everything before doing oil change.
I though after getting oil changed and everything checked, the car would be good. Right after oil change ev
erything was good until about 5 min into drive, the VDC off and slip indicator turned back on!
Should I take it back to jiffy Lube, go to a mechanic or take it to infinity dealer?
Old Sep 19, 2019 | 03:10 PM
Scorpi0's Avatar
Take it to jiffy lube and ask them to read the check engine code with their scanner. That’ll tell u what your issue is most likely. If they don’t have a scanner, drive to any auto parts store and ask them to scan it. They should do it for free.
Mosesg35
Jul 26, 2019 09:13 AM
Shaun Anderson
Apr 25, 2018 08:10 PM
nism0350gts
May 25, 2011 01:09 PM
GfGsedan87
Sep 26, 2010 02:54 PM
kotched
Sep 23, 2010 01:26 AM
