Slow start
Old Nov 24, 2019 | 05:17 PM
Hassan Young's Avatar
infiniti g 35 sedan
Slow start
G35 slow start my 06 g35 has been cracking slow I replaced both cam sensor and it still starts slow my battery is good and so is my Alternator and starters can’t figure out what’s wrong with it. It’s gave me one code for misfire in cylinder 2 but it been going on before it gave me that code
Old Nov 24, 2019 | 08:40 PM
coffeysm's Avatar
Does it start after turning it off/on or is it just take a few seconds longer to catch and then fire.
How did you check your battery too? Did you just use a multimeter or did you do a load test of it?
Check the wire from your battery going to your starter for any corrosion or bulging. Mine was a little compromised about 6 inches, so I had to cut it open, clean it up, and then reseal the wire. If you're familiar with voltage drop you can test for that too.
Old Nov 25, 2019 | 10:44 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Fix the cylinder 2 misfire first.
Next, how did you test your battery?
How did you test your starter?
Old Nov 25, 2019 | 11:45 PM
infiniti g 35 sedan
Slow crank
I tested the battery with the Nissan battery tester which fun diagnostic on the batter starter and Alternator
janda930
Drivetrain
Aug 14, 2017 12:09 PM
G35-R
Jul 23, 2017 09:01 PM
Jman214
Oct 4, 2016 05:49 AM
GarGamel
Northern California
May 28, 2012 07:05 PM
potmilkz
Jun 1, 2009 08:57 PM
