Will vq37 pistons fit in a vq35de?
Old Jan 11, 2020 | 04:14 PM
G35namedfranny's Avatar
G35 Sedan, high compression,Poncams,exhaust,porting to heads and intake,lowered on coilovers,tuned
I have done some research and I think it may work. I did a comparison of compression height between the DE,HR and VHR pistons.
I currently have my engine block on the stand waiting on pistons.
i am looking for a SLIGHT bump in compression for a all motor ported and cammed DE that has Osiris uprev software already.
my thought unless someone can tell me why I am wrong.
vq37 stock pistons, HR headgasket with MR bolts,revup pump, Tomei 264 cams,BC springs, ported heads stock DE rods with RevUp bolts.
ISR long tube headers, z1 Ypipe and custom 3inch exhaust.
I have done my homework but am not entirely confident it will work for sure. Would like someone hopefully more experienced with the VQ to chime in.
Old Jan 11, 2020 | 04:28 PM
Here is some info i found searching around.
VHR: Rod length 149.5mm, compression height 29.95mm
HR: Rod length 151.8mm, compression heigth 30.1mm
DE:Rod length 144.2mm compression heigth 29.6mm
Old Jan 16, 2020 | 04:38 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Bore is the same so they at least fit in that regard. Why not also do the 3.7 crank (assuming enough room in the bottom end), extra stroke would modestly increase low end torque.
Old Jan 16, 2020 | 04:41 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
https://www.myg37.com/forums/engine-...ml#post2923274
That may be helpful, at least in the differences and potential to handle increased power. .
Old Jan 16, 2020 | 05:27 PM
If the mains were the same size,which we already know it isn't then i would consider doing this. Would pretty much be a poor mans stroker then.
i am just looking to know if the vq37 pistons would clear the valves. I know the HR pistons fit with a thicker headgasket or slight trimming of the pistons. Just trying to figure out if the vq37 would clear without thicker gaskets or trimming since it has smaller compression heigth but doesn't have valve reliefs for the exhaust side.
dankfresh
May 10, 2019 06:49 PM
LOLmustangLOL
Forced Induction
Mar 2, 2016 02:49 PM
Invisible_space
Apr 25, 2015 12:25 AM
GT-ER
Forced Induction
57
Aug 1, 2009 10:06 PM
vinnys coupe
Jul 13, 2007 03:08 PM
