Auto trans
Old Mar 23, 2020 | 05:49 PM
Thisisntmycar's Avatar
2005 G35 auto
Auto trans
Quick question change the motor out on the g35 got the auto transmission bolted back up but the crank won’t turn by hand what am I doing wrong or is this just normal for this motor?
Old Mar 23, 2020 | 07:09 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Do you have all the spark plugs in? Remove them so you aren't fighting compression and try it.
Did you try turning the motor by hand BEFORE you installed it to make sure it wasn't a seized motor?
Old Mar 23, 2020 | 07:23 PM
2005 G35 auto
Yes the motor will rotate without the transmission mounted I’ve never had this many problems with a car and I’m stumped
Old Mar 23, 2020 | 07:47 PM
cleric670's Avatar
BANNED!!!
Ok then I suspect one of two things happened:
6MT flywheel was used instead of the 5AT flex plate, not sure if it's even possible though.
Or
6MT pilot bushing was on the crankshaft and you need the 5AT pilot bushing. You can verify from your parts kit about which pilot bushing you used.
Old Mar 24, 2020 | 11:38 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
Torque converter not on properly. When installing the torque converter it will go in half way and it takes a little wiggling to get the slots to go into the drive pump for it to seat all of the way in. It should be 25mm or about 1" from the bellhouse face to the flexplate mounting holes.
If it was installed this way it will bind and lock up like you said, but could also have damaged other things if the bellhouse bolts were completely tightened.
That is the only problem I have seen with a Automatic and binding issue over the years.
sh0rtys463
Engine - Complete Motors
Oct 10, 2012 04:02 PM
belerino
Jul 24, 2006 01:25 AM
SkylineGT
Sep 19, 2003 02:20 AM
