Vq35de vs. jdm vq35de questions
Old Mar 30, 2017 | 10:39 AM
jdmek100's Avatar
hi I have a 2005 rev up 6 speed manual and I got about 180,000 on the engine it runs fine for now but I want to start looking into a replacement. I have noticed a bunch of jdm vq35de jdm engines at different suppliers and I was curious does anyone know if there is a difference in engine because it's a rev up or am I just looking for another vq35de? I want to make sure I get the right engine for my car, also does anyone know if there are things that need to be installed on jdm engine for example when I worked with Hondas sometimes the u.s. engine had a sensor or two that the jdm counterpart did not have.
just trying to figure out all the details and what to look for when buying a replacement swap. All info is appreciated thanks in advance.
Old Apr 6, 2017 | 07:51 AM
Conway_160's Avatar
All rwd De's are the same, so as long as it's a standard De you can swap it.
De's only have one vvt selenoid, rev ups have two so the front of the motor look's different
Old Apr 6, 2017 | 11:11 AM
jdmek100's Avatar
so is the motor a different engine code for 2003-2004 I guess I'm tryin to figure out the rev up part and power difference. Not sure if power bump was a computer thing power wise or not I just want to make sure I don't end up with lower power engine so it confuses me a bit when you say they are all the same but 05 rev up got more power
thanks for your help
Old Apr 9, 2017 | 03:39 PM
Conway_160's Avatar
The rev-up didn't come out until 05 and it's NOT interchangeable with a DE, it has a different ecu and harmess.
The Rev-up got an intake VVT and shorter runners on the intake plenum giving it the hp boost, also a new oil pump. But the Rev-up also had a oil consumption problem.
Old Apr 9, 2017 | 05:57 PM
jdmek100's Avatar
yeah I figured something had to be different and not be a ecu thing. That's my main issue the oil consumption part my fix was a oil catch can so I'm not burning any oil out the exhaust like I have seen others and my last check my runners were on the clean side.
Thats my my main concern on finding the same engine used like I see others. So is there a engine code for my rev up engine to look out for jdm low mileage replacement wise?
Old Apr 9, 2017 | 06:18 PM
Conway_160's Avatar
Just look at the front of the Engine.
Rev-Up
Just get one that looks like this but have 1 intake and not two.
DE Motor
Don't get this one.
Old Apr 9, 2017 | 06:24 PM
jdmek100's Avatar
Rev-Up
DE Motor
Don't get this one.
Oh man you are the bomb good looking out, that is exactly it I can see now I truly appreciate it thank you. It helps me a lot
Old Apr 9, 2017 | 07:11 PM
Conway_160's Avatar
No Problem!
Old Mar 25, 2020 | 07:31 AM
DeborahjLinares's Avatar
Nissan Pulsar
Spoiler
Old Mar 25, 2020 | 11:32 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
None of which work on the G35...
Mosesg35
Feb 18, 2020 11:09 PM
jdmek100
Jan 23, 2019 04:22 PM
Josh_Q
Jun 11, 2013 08:11 PM
dpascual1986
Jan 30, 2009 12:39 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
