Gear oil burning smell
Old Sep 24, 2020 | 02:47 PM
Jalen Redfearn's Avatar
G35 6MT 06
Hello I have G35 06 6speed Manual and it’s leaking oil from the back of the transmission near the driveshaft smells like gear oil but looks like motor oil. Anyone else experience a Transmission leak with this Car before? Clutch was just changed out.
Old Sep 26, 2020 | 01:28 AM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
If its leaking out where the driveshaft is on the trans, my guess would be the tailshaft seal is bad
Old Sep 26, 2020 | 10:46 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Wipe it all down good so everything is nice and clean, go for a short drive, then get it back up on stands/lift and look to see what's leaking.
Really good chance they damaged the output shaft seal when putting the driveshaft back in, fortunately it's an easy fix but since it happened right after your clutch job I would make the shop that did the work fix it for free labor but you pay the cost of the seal.
scottfedm
Apr 26, 2010 07:46 PM
whoisthis
Drivetrain
Feb 5, 2010 06:56 PM
jayarayas_G35
Aug 23, 2008 04:34 PM
Klubbheads
Oct 12, 2006 09:09 PM
