Help! Car dies randomly, complete loss of electricity
Old Nov 24, 2020 | 10:28 AM
UR2EZ's Avatar
Need help diagnosing an issue....
'04 coupe A/T
Car dies sometimes right when i'm pulling out of the driveway
  • complete loss of power / electricity (no lights, dash, nothing!)
  • literally no electricity, then after a few minutes, it will start right back again
  • battery just replaced bc i thought that was the problem
    • this seemed to help for a few weeks until the problem happened again
  • no codes stored
  • fusible link at battery appears ok
Can this be caused by a bad alternator? I read that an alternator going out will not cause loss of all electric, since the battery would still be supplying the accessories...
Old Nov 24, 2020 | 11:39 AM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
Check the battery voltage when it dies - Should ~12.6 volts minimum
Check the battery cables, both (+) and (-), as well as the other electrical connections for rust or corrosion.
Old Nov 25, 2020 | 10:19 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Check BOTH ENDS of the cables, something is coming loose.
Old Nov 26, 2020 | 07:27 AM
telcoman's Avatar
Veteran: Army
'04 coupe A/T
Appears ok is not an acceptable answer
Use your multi-meter to test when the car dies to test at the battery and fusible link
It is only battery (positive) and ground (negative)
Loose or defective cables, corrosion?
FlopsDaCat
Sep 14, 2010 06:52 AM
GD-Up
Oct 9, 2008 04:05 PM
G-ridindirty
Jul 18, 2008 11:27 PM
jack_mack
May 4, 2006 02:26 PM
MIA_G35
Florida G Club
20
Mar 10, 2006 09:36 PM
