No crank no start no click no gear indicator on dash
Old Sep 10, 2023 | 10:09 AM
Z32Zapata's Avatar
2005 Infiniti g35 coupe auto trans
car died out. Couldn’t get it to crank for 30 minutes of unplugged battery. Started up and it was stuck on a single gear and revved to the moon and took forever getting up to speed died out a block away from my house now it’s a no crank no start. Nothing. Replaced shifter assembly for m mode code
replaced ipdm for corrosion on the starter relay.
replaced starter
Also noticed there is no reverse lights when the selector is in r
File Type: mov
Last edited by Z32Zapata; Sep 10, 2023 at 10:21 AM. Reason: Whole story disappeared after adding photos
Old Sep 11, 2023 | 09:28 PM
Urbanengineer's Avatar
Check to see if the ipdm behind the battery under the windshield passenger cowl is soaked with water
Old Sep 12, 2023 | 02:51 PM
Z32Zapata's Avatar
I did and there was corrosion on the starter relay so I ended up sourcing a used one and installed it
Old Oct 15, 2023 | 06:11 PM
Z32Zapata's Avatar
Bump
Bump
Old Oct 16, 2023 | 10:38 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
So you put on another IPDM yes?
What's the battery charge, have you put it on a charger to verify it's full?
gace313
May 7, 2025 09:07 AM
Polishthrust
Dec 16, 2023 11:42 AM
asma123
Jan 19, 2018 06:13 PM
aaron3719
Jun 3, 2016 04:08 AM
Quiet Storm
Jun 20, 2012 09:17 PM
