Timing chain
Old Apr 9, 2025 | 06:02 PM
chris0111's Avatar
Timing chain
Has anyone replaced a timing chain after it failed? I’m currently at that point and I wanted to know if your motor ran fine after, I’ve already took a bore scope to each cylinder and im open to any other pre cautions to make sure its not damaged. Also is there anything else I should replace while im in there?
Old Apr 10, 2025 | 08:12 PM
srv2nv's Avatar
G35 Sport
If you're replacing the timing chain, I'd suggest getting the whole kit and replacing the guides and tensioners as well. Wouldn't hurt to replace the galley gaskets with the updated ones as well as replace the water pump.
Old Apr 12, 2025 | 01:09 AM
chris0111's Avatar
If the timing chain already went bad what else should I replace
Old Apr 25, 2025 | 10:51 PM
srv2nv's Avatar
G35 Sport
Same as above. If its too far gone, you'll be replacing the engine.
What makes you think your timing chain has gone bad?
Chris_G35x
Feb 4, 2022 09:04 AM
04-6speed-sedan
33
May 4, 2008 05:13 PM
brusk
Apr 17, 2008 08:45 PM
G35 Mass
Jul 22, 2006 12:14 PM
