Help, Clunk Sound After Starting Engine
Old Mar 28, 2005 | 01:09 AM
chezwikk's Avatar
I just purchased an 05 G35 Coupe 6MT about a month ago. After about two weeks I noticed a semi loud clunk sound that happens right after turning over the engine. It only happens after the car has been sitting for sometime (usually in the morning on the way to work and in the evenings returning home). If I start once and restart soon after the clunk is gone. I turned off the radio and heating/air conditioner and it still happens. When the AC was on I heard the clunk and then the AC click on. I called the dealer and they said it was the ABS self test feature which states in the owner's manual "When the self-test occurs, you may hear a clunk noise." Just wondering if anyone else has the same thing or if the ABS story they gave me is a bunch of BS.
Old Mar 28, 2005 | 02:22 AM
Msedanman's Avatar
O.F. Administrator
Yes the ABS makes noises when initializing, also the timing chain can make a strange noise at start-up in the morning. As long as it lasts only a second or 2, you're good to go.
C.
Old Mar 28, 2005 | 07:15 AM
cato's Avatar
SouthernComfort Moderator
Sounds like the ABS system. Mine sounds like a fart, not a clunk. I think you are OK.
Old Mar 28, 2005 | 11:09 AM
malx's Avatar
Yeah I have the same thing. Infiniti told me not to worry about it. So do you guys, so I'm pretty confident everything is okay.
chinee
Jun 10, 2024 07:48 PM
derres
Aug 28, 2015 03:27 PM
chinee
Aug 8, 2015 10:11 AM
ghost_g35
Aug 7, 2015 10:31 AM
cyrus32
Jul 18, 2015 06:22 PM
