VDC, Brake, Slip light come on while driving!!!
Old Apr 13, 2005 | 08:50 AM
Soundman's Avatar
I could use a little assistance from the forum here. About a week ago, the "VDC", "Brake", and "Slip" idiot lights all turned on! I had just accelerated hard from a stop and looked down to see the dash all lite up. I stopped, turned the engine off and back on and the lights extinguished. Since then, it has happened a couple of times and when the lights are on, the "VDC" is definitely disabled. You can smoke up the back tires pretty readily. I have done the ECU reset this morning and the lights went out but I am not sure if they will stay out. Any thought on this?? Thanks.
Old Apr 13, 2005 | 10:03 AM
cato's Avatar
SouthernComfort Moderator
This sounds like the break system recall that happened a year ago. Take it to the dealer. I think t here is a recall about this.
Old Apr 13, 2005 | 01:48 PM
hooner67's Avatar
Check ur brake fluid level.
Old Apr 13, 2005 | 07:31 PM
Draco24433's Avatar
It is a brake sensor that's bad. I had it happen to me and the dealer replaced it. I believe there is a TSB for it. Be advised that while your VDC, ABS, Slip lights are on, your ABS will not work and neither your VDC. I found out the hard way. Good luck
DJ
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
newg37
Jul 26, 2015 09:32 AM
