Just did my first MOD (Z tube and K&N filter,) next is spacer via the group buy
Old Apr 20, 2005 | 06:52 PM
Sickone's Avatar
Sund: a moron with a couple of very basic tools can do it 30 - 40 minutes
Old Apr 20, 2005 | 07:08 PM
nativekhan's Avatar
Talking
I quickly read over the installation steps and while it is sounds more complicated than the ztube/k&n installation, it seems doable. My main question was how do you measure 5 torques without having a 5 torque wrench and is it that important to have the exact measure. In other words, can I guesstimate it?
Also, is there a picture by picture guide of this installation as a supplement to Tony's official installation manual?
If not, can some one make it (quick)
BTW, just ordered my 3/8" spacer from Tony, must have emailed the poor guy 35 times about random questions, although he fully answered my question, a definite pleasure to work with.
Old Apr 20, 2005 | 07:09 PM
Sundeviljay's Avatar
Coo...So, if I have the $$$, should I get the spacer or should I get a new plenum like the APS Tallboy?
Old Apr 20, 2005 | 07:21 PM
skeleton_cru's Avatar
Sedan
I would be very careful about "guesstimating" when working with the plenum. The metal is very soft and easy to strip, and there have been instances of broken bolts. You may want to invest in a torque wrench or borrow one from somebody.
Old Apr 20, 2005 | 07:52 PM
nativekhan's Avatar
Thats true about the wrench. I think I'll buy one just in case
Old Apr 20, 2005 | 10:12 PM
P_Diddy's Avatar
I don't have a torque wrench of my own, but I will probably just borrow one from the cleanroom lab at work
The dyno graph shown below only shows a 7-8 RWHP gain with the 1/2" spacer. I thought it was more than that?!?! Anyone else have any before/after dynos?
Old Apr 20, 2005 | 10:26 PM
Jp1's Avatar
Jp1
If you have the sedan, the 1/2" still fits with the engine cover(at least the 5AT version which is what I've got). It took about an hour. Yes those plenum bolts only need a couple ft-lbs of torque which isn't much. The plenum seemed to help out alot at 3.5k rpm up to redline. The mod like most will tell you rocks!
Old Apr 20, 2005 | 11:29 PM
Sickone's Avatar
the dynos vary depending on car and other mods, 8 - 12 RWHP at peak is the range.
If you are not very sure of yourself, go to the local autostore - you get a torque wrench for about 10 bucks
Old Apr 21, 2005 | 05:05 PM
nativekhan's Avatar
I am waiting to receive my spacer from Tony, which btw is a class act through and through.
I read over his instructions and am a bit intimidated about installing the spacer. How was every one's experience with the install? Any thing I should watch out for? Any tricks that might not have been mentioned by the instruction? Any advice that u wish you knew bofore installing the spacer?
Thanks
Old Apr 21, 2005 | 05:17 PM
nativekhan's Avatar
Heh, posted too soon,
Found this, FYI for others:
http://www.hypersprite.com/auto/tech-z-002/index.asp
Old Apr 23, 2005 | 12:32 AM
Hydrazine's Avatar
Using the average value of 3 pre mod runs and 3 post mod runs, it was 9.285 HP gain to be exact.
wuppiedog
Aug 7, 2015 11:16 AM
sick_sixspeed
Jul 21, 2015 01:59 PM
Ninjay16
Jul 20, 2015 01:21 AM
Cskeet
Jul 19, 2015 12:38 AM
