spring unwinding noise
Old Jun 9, 2005 | 10:27 PM
BEK27's Avatar
been noticing the sound of a spring unloading during some light driving.
Anyone know what it is?
Old Jun 12, 2005 | 01:15 AM
ZeroGen's Avatar
Omega Enthusiast
Are you lowered? Is it more of a "creaking" noise?
If so, lowering springs typically will rub during compression. This creaking sound can be reduced by adding on coil sleeves on the upper spring section where they are in close proximity to each other.
Also, this should be in the suspension section of the forum.
Old Jun 12, 2005 | 09:08 AM
amg35's Avatar
Florida G35 Club
If is shortly after you start and begin moving, it is the ABS system calibrating.
Old Jun 12, 2005 | 09:49 AM
BEK27's Avatar
not lowered, I was thinking tranny but it sounds like it could be the brakes.
Is it a sign of anything bad to come??
Old Jun 12, 2005 | 05:51 PM
Aznteazer's Avatar
how does it sound when the ABS system is calibrating?
Old Jun 12, 2005 | 06:32 PM
amg35's Avatar
Florida G35 Club
like a spring uncoiling, but just after starting up and pulling away. Happens everytime.
Old Jun 12, 2005 | 08:39 PM
Aznteazer's Avatar
the dealership replaced my axle for that noise and he seemed pretty certain but i hear the same noise as you're describing so i guess it wasnt the axles.
Old Jun 14, 2005 | 11:30 AM
jbone's Avatar
'04.5 Black 6MT Coupe
I notice a similar sound when I'm at a slow roll and hit the gas harder in 1st to 2nd. Could it be the tranny or even the heat shield?
Old Jun 16, 2005 | 12:20 PM
SLP0313's Avatar
I had the same problem. I took my car into the dealership and it turned out to be the CV joints and axles. They were replaced and the noise is gone. Not happy that this happen with only 5k miles on the car! But, it's all good now.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
DRG35R
Jan 31, 2016 07:14 AM
dcsbh1
Oct 1, 2015 03:15 PM
