SLAP STICK QUESTIONS
Old 11-28-2002 | 11:42 PM
RINO's Avatar
no matter how fast im going or stopped the car is always in 4th gear , i can be at a light and then i put it into slap stick and its in 4ths, i can be doing 100 and its 4th , is that normal?????
Old 11-29-2002 | 12:27 PM
pestilence's Avatar
Re: SLAP STICK QUESTIONS
My understanding is that it puts it in 4th as not to redline the engine if you switch to manmatic durring higher speeds. You could concider 4th manumatic the "default" setting.
<font color=green> . . : : pestilence : : . .
2003.5 Infiniti G35 Sedan .... sports/sunroof </font color=green>
Old 11-29-2002 | 01:08 PM
RINO's Avatar
no , i can be doing 10 miles per hr and then go put it in slap stick mode and its in 4th
im stopped at a light and then i put it over to slap stick mode and its in 4th
in my gf acura rsx , if im stoped at a light it at 1st
and when ever i put it into slap stick mode its in the gear im driving in
Old 11-29-2002 | 02:37 PM
EdRedS's Avatar
The reason for this is that when you switch over to manumatic it's automatically put in fourth. While in fourth it will change gears just like in automatic...whatever gear you put it in in manumatic it will change gears for you up to that gear. example: if in 4th will switch 1-2-3-4 for you...if in 5th will switch 1-2-3-4-5....if in 3rd will switch 1-2-3. This is to prevent you from hitting the rev limiter.
Red/Canadian
Old 11-29-2002 | 07:00 PM
pestilence's Avatar
Exactly. Thats what i was trying to explain by saying: You could concider 4th manumatic the "default" setting.
Old 11-30-2002 | 02:44 AM
RINO's Avatar
even when stopped?
4th gear ???????
slap stick sucks
Old 11-30-2002 | 08:05 PM
Merlin's Avatar
Staff ALUMNI
Rino,
Even when stopped. You have to change down to 1st.
Merlin.
Old 12-01-2002 | 11:45 AM
RINO's Avatar
yeah but in most other slaps stick if ur at a stop and put into slap stick mode , its on 1st gear
so why when im at stop and then move it to slap its 4th , cars arent supposed to start at 4th gear
anyone want to buy my G35
I WANT MY 2K MAX BACK!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 12-01-2002 | 04:27 PM
envykillz's Avatar
5th gear is not overdrive.
and when u switch it over it goes into 4th .. as a precaution.
its easy to slap that thing over. so if you where at a stop, or your passenger hit it without you knowing it, and you hit the gas it will not bounce off the rev limiter
Old 12-02-2002 | 06:37 AM
skeleton_cru's Avatar
Sedan
I agree, sell your G35. The car is not made for you. By the way "slap stick" is a type of comedy, not a type of shifter.
Old 12-03-2002 | 09:29 PM
gaklid's Avatar
<hr></blockquote>
I'm glad somebody else said it...
Ivory Pearl/Premium/Xenon/
Old 12-05-2002 | 01:03 PM
RINO's Avatar
nooooo the maxima wasnt a joke ,
the g35 is VERY over rated, yeah it got car of the year .....why ??probaly nissan paid motor trend a lot of money to advertise but its still only a "NEAR LUXURY CAR"
i know most of you think or try to convince your self its the greatist thing next to white bread but its not
i had my 2000 maxima se , it was roomier ,built better with better material. comfortable, bigger trunk, bigger glove box
the only reason i didnt get the 2003 maxima is because it has the same body style as the 2000 and i wanted something different.... if you have a second go to the nissan dealer and check one out
i like the g35 ,if i didnt i wouldnt of bought it but your paying xtra for the name not for quality
and yes SLAP STICK is another name for a type of shifting
let me prove my point to you BUDDY
STICK is another name for a manuel......correct ??
what do you do to shift gears in a triptronic, you SLAP the STICK
meow
ps.....
as infiniti says
"Flick the shifter sideways and you're in manual mode, which allows sequentially selected manual gearshifts".
Quick Reply: SLAP STICK QUESTIONS
