Easy Ecu Resetting
Old Aug 15, 2003 | 10:14 PM
  #46
G35_PR's Avatar
Re: Resetting the ECU
Every time I do the resetting the Service Engine Soon light kept flashing during the first drive until I turned off and started again. Anyone else?
Old Aug 15, 2003 | 10:19 PM
  #47
6speedG35sedan's Avatar
the service engine light turned off after the reset for me. I followed the instructions then took the key out of the ignition before starting the car to drive for the first time after the reset. When you were doing the reset did the engine service light start to blink quickly after you held the pedal down for ten seconds the second ten second interval? Well those are my ideas. Could you feel a difference on the first test drive?
Good Luck
Old Aug 15, 2003 | 10:22 PM
  #48
Oh yeah by the way,the 6 speed didn't turn into an Automatic. Phew!!!
Old Aug 15, 2003 | 11:55 PM
  #49
Msedanman's Avatar
O.F. Administrator
Excellent write-up and great to hear that it worked for you. It sounds like there are other parameters in the ECU that benefit from the reset. Great news, and thanks for posting bro
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Old Aug 16, 2003 | 01:29 PM
  #50
G35_PR's Avatar
The Service Engine light blinks and then turned off, but for me it started flashing during first drive, I didn't take off the key out of the ignition maybe thats why it kept flashing.
Old Aug 17, 2003 | 08:37 PM
  #51
350GTSkyline's Avatar
I don't understand why you need to reset the ECU... 1st of all can't you drive with Manual shift when power is needed, 2nd how long does it take for the ecu to accept new driving styles. for instance, do I have to punch it really hard for 2 weeks before the ecu is loaded with new data...
Old Sep 17, 2003 | 01:07 PM
  #52
satch's Avatar
Re: EASY ECU RESETTING
Let me the first to say this does not work I can never get the CES light to blink..... I tried 20 time with a second hand... I have an auto 35
Old Sep 17, 2003 | 03:23 PM
  #53
ncozby's Avatar
50 different people post here saying they had success. Now since you couldnt succesfully perform the reset, it doesnt work? I guess we are all just imagining things.
Get real.
2003 G35 BS Sedan AT
Premium, Winter,
35% Tint All Around - Clear Side Markers
Custom MB Quart / Eclipse Stereo System
PIAA Hyperwhites All Around & Inside
Old Sep 17, 2003 | 03:28 PM
  #54
cato's Avatar
SouthernComfort Moderator
Let me be the last to say that this definitly does work. You just
are not doing the process correctly. I have done it at least 5 times.
Lots of others on this board have done it as well. Reread the
instructions and try try again!
2003 Twilight Blue 5AT Sedan, sunroof,
Graphite Leather, splashguards,
GG/DB red 12 wire Hyper-grounding kit,
350Z intake duct, Stillen Hi-Flow Airbox
Old Sep 17, 2003 | 04:17 PM
  #55
OOOOA3's Avatar
Alumni****
-satch
it took me a lot of times to do it too.. it's really about timing.. i didn't follow the exact directions as described, but i still got it to work eventually.. don't give up.. i did it and it really does work..
Old Sep 17, 2003 | 05:08 PM
  #56
pratG35's Avatar
Yes, Easy Reset does work to reset the engine ECU but not the tranny ECU. My tranny ECU still takes a long time to shift. Hard Reset (disconnect battery) brought my tranny back to life. Shift much quicker now and more willing to shift even if the gas paddle is only partially depressed. I am going to hard reset it once a month on the 1st.. makes it easy to remember. Probably easy reset every 2 weeks..
-PratG35
Old Sep 17, 2003 | 07:58 PM
  #57
G35Newbie's Avatar
I tried 5 times and it didn't work. Then I realized both my windows were down. After I closed my windows, it worked after the first try.
Old Sep 17, 2003 | 08:12 PM
  #58
khsonic03's Avatar
I did it to my AT sedan right after installing my stillen intake, and it worked on the 3rd try. My driver's window was down too. It helped to use a watch with a second hand.
'03.5 Brilliant Silver Sedan
Premium, Aero Kit/Package, Sport, Winter
Stillen Air Box, Clear Corners, Alum Pedals
Old Sep 18, 2003 | 03:17 AM
  #59
gdupg35's Avatar
I did the ecu reset about a week ago and it took me almost ten tries to get it right. I'm a little skeptical if it really did anything to the 6mt. It feels a little faster... but I think it is just my imagination.
Ah who cares. All I have to do is flick that little nitrous swtich to ON and screw the ECU!!!!!!!!!
Old Sep 18, 2003 | 08:22 AM
  #60
SixFive's Avatar
ECU reset works on auto better as the manual cant be trained like the auto to granny after awhile. THe ecu reset is much nmore noticable on a 5at with mods. I have injen and 30 days between resets mean a large difference in sound and performance.
