Easy Ecu Resetting
Old Jan 24, 2005 | 07:03 PM
  #196
pluggins's Avatar
wow i think you just gave me a flashback!
Old Feb 21, 2005 | 04:00 PM
  #197
cato's Avatar
SouthernComfort Moderator
Originally Posted by gordgee
Found this.
<font color=green>GG</font color=green>
Darn it! This link does not work anymore! Gord, can you fix it.
Old Feb 25, 2005 | 01:11 PM
  #198
SolidForce's Avatar
easy ecu reset?
No need to disconnect the battery for 12+ hours, thats just a waste of time.
D/C the battery, keep the positive on it though, take off the negative and hit your brakes ~5 all the way to the floor.
This kills whatever was leftover and should reset the ecu back to normal.
-SF
Old Mar 6, 2005 | 04:07 PM
  #199
dwoloz's Avatar
Isnt there just a fuse for the ECU that can be removed?
Old Mar 11, 2005 | 03:37 PM
  #200
Calgary_G's Avatar
won't reset.
Originally Posted by gsedanman
I've done 2 things. 1/ Checked the ESM (section EC-68) for confirmation of this procedure, and 2/ done the procedure on my G.
I tried several times to do this without success b4 succeeding on about the 4th try.
-------------turned ign. to on & waited (only) 3 seconds- <font color=red>just 'on', not started! </font color=red>
--------------floored and released gas/p 5 times within 5 secs.
--------------waited 7 secs then floored gas/p for 10 secs at which time the check engine light blinks
------------- release gas/p
------------- floor and hold gas/p for 10 secs.
-------------your done.
<font color=red>seems timing is very important on this</font color=red>
I've done the procedure but have no idea if it's had the desired effect yet. Won't know that 'till later today.
If successful, this looks like any easy way to erase the ECU's memory. I'll post my impressions later. Would someone else try it too?
<font color=green>GSM</font color=green>
OK I have checked my gas lid, I have unhooked the ground for 12 hours, I have pumped the pedal as instructed, trying that at least 12 times. I can't get the service engine light to even start blinking? All I did was install a new K & N filter and unhook the wiring on the intake. I did start it momentarily when the wiring clip was unhooked but never drove it. Noticed it & hooked it up, and now still can not get this f***in light off! Any more suggestions would be so appreciated??? The car seems to run fine, just the lights on? Go to dealer? Thank you
Old Mar 11, 2005 | 05:43 PM
  #201
SolidForce's Avatar
Do what I said earlier in this thread...make sure everything is hooked up right...
After about half a tank of gas or so it should disappear as the ECU will start going through a check sequence making sure everything is ok.
Worse comes to worse, find someone with an OBDII scanner and have them clear it for you. I think Autozone still does it but they might charge now.
-SF
Old Mar 11, 2005 | 06:22 PM
  #202
dwoloz's Avatar
After my fifth try I got it
Some tips: (probably all been stated already)
Make sure after each attempt you turn off the key and then turn it back on
Try waiting a bit more than 7 seconds before holding the gas. I did it for exactly 7 and it never worked. Then I tried 8-9 and the first time it worked for me
Just keep at it
It really does work
Old Mar 24, 2005 | 09:53 AM
  #203
eaurouge's Avatar
reset ecu after adding cold air intake
about a year ago i added a K&N cold air intake, and ever since it has not been idling right. i disconnected the battery for about a minute. that seemed to help a bit, but it's never been the same. would the procedure you've described work for this or is it just for getting rid of the "check engine" light?
Old Mar 24, 2005 | 10:08 AM
  #204
InfinitiTech's Avatar
Seen it before too many times, the cold air intake may set the light and run rough, stock, the vehicle is designed to run with a factory air cleaner, put the factory one in and I bet it goes away. Probably not what you wanted to hear, but true
Old Mar 26, 2005 | 08:15 PM
  #205
maxpower's Avatar
Thumbs up
Originally Posted by SolidForce
easy ecu reset?
-SF
SolidForce,
I tried your "Quick Disconnect" method and it worked great. The somewhat 'lazy' shifting was gone and it drove like the day I brought it home
Thanks for the valuble tip
Old Apr 9, 2005 | 05:54 PM
  #207
C_Lawd's Avatar
easy ecu reset?
-SF
Does this work for 6MT?
Old Apr 18, 2005 | 07:41 PM
  #208
SQconstable's Avatar
I got my dealer to flash the ECU before I read this post.. cost $95 but he bumped up the ignition timing by 3 degrees. It seems to help acceleration and get to higher RPM's more quickly.
What I'm wondering is if the disconnecting of the cables and grounding them will erase that modification to the ignition timing? I'd like to preserve it if possible yet be able to fully clear the ECU on a monthly basis.
Old Apr 18, 2005 | 08:47 PM
  #209
SixFive's Avatar
WHAT??? Could you please repeat the part about bumping the timing and the 3 degrees? WHat dealer?
