Easy Ecu Resetting
Old Sep 29, 2005 | 01:39 PM
  #241
big daddy d's Avatar
Originally Posted by nova33
Stupid question but what is the point of resetting the ECU? IS this procedure only for after you get the aftermarket ECU?
It activates the SEARCH button on your desktop for G35driver.com.
Old Sep 30, 2005 | 10:58 AM
  #242
Infinite G's Avatar
LOL!!! yes, it certainly does
Old Nov 11, 2005 | 10:12 PM
  #243
Dark Genesis's Avatar
I believe I successfully resetted the ECU, do I just remove the key after it blinks fast the second time or just start the engine? I have 1500 Miles on my car and I can't feel the difference so I want to know if I wasnt suppose to start the car after the light starts blinking uber fast the second time.
Old Nov 17, 2005 | 05:54 PM
  #244
fx45copper's Avatar
Just did the procedure on the 3rd try after I found out about pressing the gas pedal 1 time per second for 5 seconds. Now the check engine light no longer blinks after i started the car....car didnt seem to run any different after I started it for the first time - havent taken a test drive yet
Old Nov 21, 2005 | 05:15 PM
  #245
Dan_K's Avatar
Would disconnecting the battery also reset the ecu?
Old Nov 21, 2005 | 07:03 PM
  #246
RBull's Avatar
Rated M
Yes, 12 hours is the suggested time for the disconnect.
Old Nov 22, 2005 | 09:15 PM
  #247
G35NB's Avatar
hey guys i keep trying to do the reset to my 2004 6mt coupe but i cant get it to work...does nay one have detailed instructions? do iput the clutch in when i do it? does it have to be exactly 3 secs, 5 secs etc? does the check engine light definatly blink ?
Old Dec 1, 2005 | 09:49 PM
  #248
fx45copper's Avatar
I finally am doing the overnight reset.. I just want to know for sure it worked lol- removes all doubt :P
Old Dec 5, 2005 | 07:57 PM
  #249
devenyi's Avatar
Either I am the most useless person in the world, or my car just refuses to cooperate. At no point does my check engine light blink.. apparently I am not the only one having trouble with this..Persumably it should work though... its an 04 6MT coupe w/ nav... if there's some reason why it wont please let me know, so i can stop wasting my time... but i really would like to get it working... so if anyone has some pointers that I haven't read on the thread, please let me in.. thanks
Tyler
Old Dec 6, 2005 | 02:48 AM
  #250
fx45copper's Avatar
Remove the negative terminal for 12 hours, simple remedy to all your doubts/problems
Old Dec 6, 2005 | 01:57 PM
  #251
devenyi's Avatar
Looks like thats what I'm going to have to do.. This seemed like more fun though... apparently I am completley useless though... its amazing.
Old Dec 20, 2005 | 01:44 PM
  #252
99atlantic's Avatar
i just yank it for 24hrs
Old Dec 20, 2005 | 02:34 PM
  #253
emineo's Avatar
I got this to work on my first try, definately tickles my pickle. Also going to try the battery method. If that works, it will definately lube my tube.
05 IP coupe / 5AT.
Old Dec 28, 2005 | 05:13 AM
  #254
68 Z-28's Avatar
Originally Posted by dkeystone
One question:
After I reset the ECU once and drove the car around for a while, I tried to do it again (just to make sure I had the procedure down). I got all the way to the slow-blinking Check Engine Light, took my foot off the gas pedal, then put it back down for the final 10 seconds. The Check Engine Light continued to blink slowly - - but it never blinked quickly and it just went back into regular illumination mode. I, apparently, didn't get it into that final reset mode. Any thoughts? Do you have to log some time on the ECU before it can be reset again?
Thanks for any input you guys might be able to provide.
I'm getting this same result. I was able to succesfully reset it before, but just get the slow blink for 4 flashes and on the 5th it stays solid. Anyone know what may be up with that?
Old Jan 22, 2006 | 03:43 PM
  #255
cloud's Avatar
Would resetting(or failing to reset) the ECU potentially screw anything up?
