Kinetix Plastic Plenum oil leak?
Old Jan 19, 2006 | 10:47 AM
Nodnarb901's Avatar
When I bought my G35 used from the Acura dealership I work at, it already had some mods, including the Kinetix upper plenum. I noticed the other day there seems to be a very very small oil leak from the gasket under the plenum.
Now from what I know about motors, I know there is no oil being pumped through the plenum, but a little will make it's way into it.
Has anyone ever seen this before?
Old Jan 21, 2006 | 10:05 AM
Nodnarb901's Avatar
Update, I think I found it, all the bolts holding the Plenum on were not all the way tight. I guess previous owner didn't get them properly tightened.
Old Jan 21, 2006 | 11:15 AM
blazinZ's Avatar
let me know if theres still a problem. i'm about to install mine but before i do i would like to know what the outcome was.
Old Jan 23, 2006 | 11:51 PM
panda007's Avatar
i used a bit of silicone to the cork gasket for reassurance. it looked ugly, but it worked.
Old Jan 24, 2006 | 12:08 AM
norcal_chan96's Avatar
Do you guys like your plenum? I have the Kinetix's as well, but it makes an annoying sound at low RPM's.... Do you have the same problem? I kinda like the stock set up...
murphd3rf
27
Oct 16, 2023 02:15 AM
RA102223
Aug 15, 2015 09:24 PM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
itztwinki3
Aug 11, 2015 05:52 AM
ClwMike
Jul 23, 2015 12:55 PM
