tech says pinging, but i think different
Old Dec 27, 2005 | 12:30 PM
giovanni4414's Avatar
i am hearing some noises and the tech at miller said that my 6mt was pinging. ran some injector cleaner and octane booster and it still makes the noise, but not as often. what kind of noise did your trannies start making when you first noticed. my father seems to think it is low on gear oil. noise starts on hard accl in 1st and 2cd gear around 4k rpm's. also makes noise when the car is cold on hard accl in 1st and 2cd.
Old Dec 27, 2005 | 07:37 PM
G_Man8895's Avatar
I get the same noise from the engine once in a while. It usually happens when the engine's still cold and I'm accelerating in first or second gear up a slight hill. I've always used 93 octane, so I'm not sure what's causing this noise.
Old Dec 27, 2005 | 07:41 PM
MikeyMike's Avatar
Rollin On Dubz
Who's your tech? You're talking about Miller of Van Nuys right?
Old Dec 28, 2005 | 03:08 AM
G35SanDiego's Avatar
Are you experiencing what seems to be a hicup in the engine, which could be attributed to pinging, except because it also has a spinning metal clunck to it that seems to originate from the tranny?
I had this symptom, dropped some injector cleaner in it and seemed to improve but it is still present, I think the improvement is in my head and it a tranny related issue. I know for a fact that my tranny is louder and less smooth than day one by a significant amount.
Hoping it blows up or gets worse so that I can go in for warranty work without having to convince the stealer.
Old Dec 28, 2005 | 12:06 PM
i have the car serviced at miller infiniti in van nuys. i forgot the techs name. for right now i dont think it is spinning metel. i had the bearings re-packed already, but i once noticed that there was a spinning metal noise when i was on a turn under full load and all the weight was on the left side and it seemed like the right rear was free spinning with some metal noise. havent gotten it since. got to try that turn again. IF YOU GO TO MILLER, BE CAREFUL WHAT IS IN YOUR CAR. I HAD CHANGE STOLEN AND $40 IN STAMPS. the service mgr did nothing.
Old Dec 28, 2005 | 03:29 PM
MikeyMike's Avatar
Rollin On Dubz
Gio,
Honestly bro, no place is liable for what you leave in the car. If I give my car to the dealer, valet, where ever.........if I leave anything in my car I wouldn't mind if it was stolen...so whatever I wouldn't want stolen I take out with me.
There's one tech at Miller, Gene Lee.....steer clear of that guy. I wouldn't be surprised if he was your tech who couldn't help you the right way.
Old Dec 28, 2005 | 05:17 PM
i dont know if it was him, but there was a hispanic guy who road with me in the car. he wasn't to bright. he tried to say that the ping came from a dirty air filter. not possible.
Old Dec 30, 2005 | 04:48 AM
Gaaaar's Avatar
How does the noise sound like exactly?? I dont think my engine is pinging but then again i dont know what to listen for.
Old Dec 30, 2005 | 01:45 PM
the noise comes on around 3000 rpms in first or second gear. it is very noticeable when the car is cold. it kind of sounds like clicking.
Old Jan 8, 2006 | 12:44 PM
soflkurtz's Avatar
i also get the same ping in low gears, mostly right off idle. dealer said nothing is wrong. i also had some other noise known to affect 6MT coupes (i have a 6MT sedan) and that was fixed, but the ping is still there.
there are some other similar threads in 6mt.net which reaffirms that i am not totally crazy.
it bothers me because i don't want to cause engine damage long term.
could this be a regional gas issue? i am in the miami, fl area and 91 is the highest octane i can get. can the pinging be determined from an infiniti diagnostic test and captured?
anyone figure this out yet?
--- bone stock 05 6MT sedan except for K&N filter, 11K miles
Old Jan 24, 2006 | 02:19 PM
MarkG's Avatar
Pinging is more likely when the engine is hot, especially under load. I don't own a G35 (yet) but it could be a heat shield vibrating on the exhaust. I noticed something similar on my G20. Goes away quickly when it warms up.
Old Jan 24, 2006 | 07:28 PM
CBRworm's Avatar
20 Year Member
Why can you only get 91? I am just north of miami and always get 93.
KruZZe
Feb 27, 2023 05:04 PM
prinny
Nov 22, 2015 11:07 PM
AJC128
Nov 1, 2015 11:55 AM
reaper76
Sep 20, 2015 11:59 AM
