Service Engine Soon MREV Installed --- NEED YOUR HELP!
Old Jan 27, 2006 | 11:11 PM
socal-oc's Avatar
Exclamation Service Engine Soon MREV Installed --- NEED YOUR HELP!
Hey guys,
Today I just installed the MREV PLUS with the Copper ISO.
Installation went pretty good and straight forward. Double checked everything , check all hoses, put the electronic throttle plug back, and check bolts to torque recommendation.
I started the engine and let it warm up for 5 min....came back and sat down and noticed that darn "Service Engine Soon" light is lit up.
I turned off the engine and waited 5 mintues. Started her up again and the the "Service Engine Soon" light is back.
I tried to search the forum...and I have to say that search engine needs improvement. The only thing I found was to dis-connect the battery overnight.
Is there anything else I should do or check ? Please help.
Thanks
Johnny
Old Jan 27, 2006 | 11:25 PM
Hydrazine's Avatar
Try this pedal reset procedure.
http://www.my350z.com/forum/showthre...=THROTTLE+BODY
Scroll down to DaveO's post for full details.
EDIT:
Here is the text.
* Accelerator Pedal Release Position Learning Procedure.
1. Make sure that the accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds.
* Throttle Valve Closed Position Learning
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch is “ON”.
3. Turn ignition switch is “OFF” wait at least 10 seconds.
Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound.
* Idle Air Volume Learning (Throttle Position Learning)
It's best to time with a watch/clock.
1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Conform that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications.
* ECU Accelerator Pedal Reset Procedure
Note: Timing is critical for this to work!
1. Turn the ignition switch to on. Dash gauges lit. Don’t start the engine!
2. Wait 3 seconds.
3. Fully depress and release the accelerator pedal 5 times within 5 seconds.
4. Wait 7 to 10 seconds.
5. Fully depress the accelerator pedal for approximately 10 seconds. At this point the check engine light starts to blink quickly indicating Diagnostic Test Mode II (Self-diagnostic results) has started.
6. Release accelerator pedal and wait 5 to 10 seconds.
7. Fully depress the accelerator pedal for 10 seconds. At this point the check engine light should change to blinking slowly indicating “Erasing ECU Memory”.
8. Release the accelerator pedal and turn the ignition switch to off.
9. Restart the engine. The check engine light should be out.
Note: If the check engine light doesn't blink as described in steps 5 & & 7, then the ECU isn't reset.
* If above didn't work, you'll need to disconnect the battery negative for 24 hours. (I pump the accelerator and brake to "bleed down" the ECU memory for good measure.) This method is almost foolproof as long as all ECU control parameters are within their normal ranges.
Tony
Old Jan 27, 2006 | 11:36 PM
socal-oc's Avatar
Tony,
Thank you for the fast info and input.
I will give that a try. Will post the results.
Thanks
Johnny
Old Jan 28, 2006 | 12:46 AM
socal-oc's Avatar
Worked like a charm Tony !
Thanks.
MREV....OMG.....best money spent. First start up sounds wicked. Revs and pulls hard.
Very happy customer. Thanks again.
Old Jan 28, 2006 | 01:12 AM
99atlantic's Avatar
EDIT:
Here is the text.
Tony
are you actually working on more stuff for the g35?
Old Jan 28, 2006 | 12:03 PM
Hydrazine's Avatar
Hahahaha! Heck yeah! There is so much more to do.
Development and testing is going to be lots of fun.
Old Jan 28, 2006 | 02:05 PM
35bills's Avatar
Tony,
What does Motordyne have in development( if you can say).
Please tease us all!!!
Old Jan 28, 2006 | 11:43 PM
Hydrazine's Avatar
Everything from intake to exhaust tips. Its all in the works.
jsimonk
Dec 22, 2023 03:49 PM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Team STILLEN
Aug 10, 2015 08:17 PM
sick_sixspeed
Tuner & Dyno
Jul 21, 2015 03:23 AM
igking
Jul 19, 2015 01:12 AM
