"closed loop"
Old Feb 12, 2006 | 01:13 AM
geeitup's Avatar
"closed loop"
Anybody run a diagnostic tool on their engine and know at what load it goes "closed loop." I have a friend developing a plug-in that will run between the ECU and the fuel injectors - apparently larger gains can be had if the factory ECU goes closed loop relatively early, or is completely closed loop. If you don't know what I'm talking about, don't ask, because I don't really know myself.
Old Feb 12, 2006 | 01:47 AM
GEE PASTA's Avatar
Florida G35 Club
My understanding is that closed loop is when you have the cruise control set and then ECU is set to the most lean condition the engine can handle. Playing with this should show no gains at all. I would stay away with playing around with closed loop.
If you want more information, I would PM DaveO.
Old Feb 12, 2006 | 10:20 AM
CBRworm's Avatar
20 Year Member
If you watch with a consult, or obd reader, it is only in closed loop when idling, and cruising. as soon as you step on the gas more than just a little - it goes open loop. There is also an rpm limit for closed loop, I am not sure what it is but probably around 3,500-4K. After that it goes to a fixed map.
What I want to find out is if the long term fuel trims learned in closed loop mode are applied in any way to the open loop map.
KruZZe
Feb 27, 2023 05:04 PM
bananax
Sep 24, 2019 12:24 PM
master111
Sep 25, 2015 08:32 PM
