Expected Gains for these mods?
Old Feb 15, 2006 | 02:16 AM
Strtsk8r321's Avatar
Why are all the advertisements for these BS? The spacer claims 12-14hp, the pop charger claims 6.5hp, and many z-tube websites claim 7hp. Thats obviously not true because that would be over 26hp.
Old Feb 15, 2006 | 06:36 AM
2FastG354U's Avatar
Can you put the Motordyne MREV Plenum Kit 350Z, G35 W/300hp Rev Up Motor on a 280hp Auto or does it have to be the Motordyne 5/16" Plenum Spacer and Iso-Thermal Gasket Kit?? Would I see better gains with the MERV plenum??
Old Feb 15, 2006 | 09:11 AM
jnkirk1974's Avatar
Fastest G35 In Rockwall
You probably won't see MORE benefit. You just need to get the non-MREV Iso Thermal gasket and the 5/16" spacer.
Old Feb 15, 2006 | 01:20 PM
99atlantic's Avatar
i've readt that putting mrev on a non-rev up engine will actually make it loose power across the entire band
and likewise, i've read that using just the spacer on a revup will not result in any power gain.
Old Feb 15, 2006 | 01:50 PM
Hydrazine's Avatar
No, its the "REVUP" lower plenum that does this. Not the MREV.
The two are almost opposites of eachother.
This is true.
Old Feb 15, 2006 | 03:59 PM
trey.hutcheson's Avatar
Just for clarification, the MREV combines an OEM non revup lower collector with an iso thermal spacer(additionally, the Plus option machines two runners on the lower collector). Therefore, the MREV is inappropriate for non-revups because the non-revups already have the OEM collector. Non-revups however do benefit from the iso thermal plenum spacer.
So, if someone attempted to put an MREV on a non-revup, he would see the same results as if he just used a spacer.
Old Feb 15, 2006 | 04:03 PM
99atlantic's Avatar
oooh, i see.
Old Feb 18, 2006 | 03:14 AM
threatcon07's Avatar
Originally Posted by Gaaaar
Ztube, Popcharger and the spacer will probably only give you about 10-12 HP at the crank.
And that would be on a good day....just out of curiosity; when you guys are discussing hp increases on this forum; do you always use crank horsepower rather than wheel horsepower??
Old Feb 18, 2006 | 03:25 AM
According to SZM's results; the 5/16 spacer should give you 6.5 - 9.2 hp at the CRANK.....I believe that you would only see those type of gains using a z-tube would be on a car that has some form of forced induction. On a car w/ bolt ons you would not see 1-3 hp gain from a z-tube.
Originally Posted by GEE PASTA
On your car the 5/16 or 1/2 spacer should give you a solid 10 HP plus. Z-tube is worth maybe 1 - 3 HP then maybe a set of high flow cat's 2 - 5 HP gain. A good y-pipe setup should get you right there at 300 @ crankshaft.
Happy modding
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Usman Ali
Oct 4, 2015 08:23 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
