engine revving while i'm stopped... what's going on?
Old Feb 26, 2006 | 02:56 PM
absolutg's Avatar
workin...
hey guys, so last night i was trying to make my way over to HIN in san jose and i noticed a weird behavior with my car. i'm not sure it's a problem, but it did feel pretty strange.
i was in a parking garage, looking for a spot, so lots of stop and go driving. when i'd push on the brake to come to a complete stop, i could feel the engine "revving" a bit, like it was fighting my braking. here's the weird thing, i'd look at the tach, and the rpms would just stay @ 800 or 1000. i could feel some vibration in the brake pedal. if i took my foot off the brake, i could see the rpms slowly increase from 800 to over 1000 without me applying any gas. when i was at a full stop with the brake applied, i could hear the engine working louder than usual and my friend who was with me said she could hear it too.
i'm not sure what to make of it. it could be that this is somewhat typical and i'm not used to it (i had the AC on, which i don't usually turn on).
should i take this issue to the dealer and get it checked out?
Old Feb 26, 2006 | 03:28 PM
godmans's Avatar
Did you accidently push the gas and the brake at the same time? I sometiems accidently touch the edge of the gas pedal when i brake hard
Old Feb 26, 2006 | 04:10 PM
absolutg's Avatar
workin...
i thought that might be happening so i was careful to make sure i wasn't pushing them both @ the same time when i observed this problem. that's a good point tho.
Old Feb 26, 2006 | 05:12 PM
Msedanman's Avatar
O.F. Administrator
With the A/C on, engine revs higher so it won't stall.
Next time it happens, turn a/c off to see if the idle comes down to normal.
C.
Old Feb 26, 2006 | 05:30 PM
dofu's Avatar
20 Year Member
I get the same thing happening every now and then... I thought it might be because I'm on the brake and throttle as well, but it's still revving when I have both feet in the air... feels like the throttle gets stuck at times...
If you're sitting still and your idle is just going up down, then you have a vacuum leak somewhere. That might be my problem too...
Old Feb 26, 2006 | 05:50 PM
absolutg's Avatar
workin...
thanks for the tips guys. i just went for a 20-30 minute spin and didn't have the problem reproduced with that A/C on. i'll just have to keep my eyes open for it. i hope it's not the vaccum leak
Old Feb 27, 2006 | 05:31 PM
shunra's Avatar
This is probably a vacume leak in your brake booster. Seen it before in older cars where there was a problem with the vacume assist. Whenever the breaks were applied a small vacume leak would develop and the idle would increase. If I were you I'd have the dealership check/repair/replace your brake booster.
Old Feb 27, 2006 | 06:16 PM
99atlantic's Avatar
my dad's i30 used to do that in the winter - infiniti said it was somethign w/ the a/c and normla.
Old Feb 27, 2006 | 06:28 PM
shunra's Avatar
Well the idle is bumped by the ECU both when it is cold and when the A/C is on - and that is normal. However if the problem occurs when you push the brake pedal (irregardless of A/C) then it is probably the brake booster with a leak. I've seen it so bad that you can actually hear the hissing from the leak when the breaks are pushed.
It could be just my experiences but it seems like the delerships more often than not say it is "normal" when they don't have a solution/explanation for the problem. Sometimes I think they don't know their a$$ from a hole in the ground.
Old Feb 27, 2006 | 07:03 PM
absolutg's Avatar
workin...
shunra: thanks for the info! i'm going to see if it keeps happening, if it does, i'll definitely take it in and have them check that out
Old Feb 27, 2006 | 08:40 PM
99atlantic's Avatar
Well I don't think it was a leak - this last happened over a year ago and hasn't since.
Freeman186
Sep 6, 2023 10:07 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
alessandro
Oct 8, 2015 09:29 AM
Joe Gargano
Sep 18, 2015 11:17 AM
Jnm07
Sep 5, 2015 01:16 AM
