Technos ECU Dyno?
Old Aug 31, 2003 | 10:54 AM
petrog35's Avatar
Technos ECU Dyno?
Has anyone done any before and after dyno runs on the
Technos ECU? I'm interested in seeing what the torque
and HP increases are.
Old Aug 31, 2003 | 05:47 PM
nuttyprof's Avatar
Re: Technos ECU Dyno?
soon. very very soon. 1 week.
G35S 6MT
K&N FAI
Technosquare ECU
6-wire ground kit
Quantum tint
Custom sunshade
Old Sep 1, 2003 | 08:11 PM
petrog35's Avatar
nuttyprof
can u post the information when u dyno your car.
Old Sep 1, 2003 | 09:05 PM
Gsedan35's Avatar
Yes please post the dyno sheet. I'd like it to read the rpm's from 1.5k to redline.
Thanks in advance
BTW, I think the info that StrictlyZ has on the technos ECU is the best info I've seen on the ECU system, just my 2 cents.
Ivry 6mt sed
Crawford Pleneum
Injen CAI
22" resonator
Cusco sway bars
350Z springs&struts
Enkei RPM2
Old Sep 2, 2003 | 12:16 PM
petrog35's Avatar
I know StricltyZ has the best info, I just want to see what
other people gained with this ECU mod.
5AT/DG/Premium/4pc.Aero
Injen CAI
Aluminum Pedals
18" Factory Chrome Wheels
Old Sep 2, 2003 | 12:48 PM
malx's Avatar
I want to see these dyno sheets. I CAN'T WAIT! [img]/w3timages/icons/smile.gif[/img]
Thanks - Joey Avino
Old Sep 3, 2003 | 01:48 AM
nuttyprof's Avatar
i will be getting my ecu back on thursday with the new program. i will post on my butt dyno results and the improved driving feel, etc, etc. as for official dynos, i will probably get them next week when i bring my car in. hopefully, bone stock, then with ecu, then with ecu and K&N Typhoon intake. patience is a virtue...keep waiting. hahahaa.
G35S 6MT
K&N FAI
Technosquare ECU
6-wire ground kit
Quantum tint
Custom sunshade
Old Sep 3, 2003 | 08:06 AM
petrog35's Avatar
I can't wait! Good luck.
Injen CAI
Aluminum Pedals
Old Sep 5, 2003 | 07:48 AM
nuttyprof's Avatar
got my ecu back with the new program(beta version) but havent really had time to drive around yet. i did mash the pedal a bit in 2nd going down my street and it does pull much harder past 3k rpm. havent tested the redline yet either.
can someone give me some info on what knocking sounds like?
when in idle, my exhaust makes a small, but noticable burping noise every ... ~1.5 seconds im guessing. is that not good? keep in mind, this is a beta version so you guys wont have the same problems, if it is a problem...
G35S 6MT
K&N FAI
Technosquare ECU
6-wire ground kit
Quantum tint
Custom sunshade
Old Sep 6, 2003 | 05:37 PM
petrog35's Avatar
nuttyprof
usually you hear knocking and pinging at w.o.t. if there isn't
enough fuel or too much timing not at idle.
Is your car idling rough or smooth when you hear this burping
sound?
It almost sounds like your car is running really rich. I had a
mustang that was modified and kind of did the same thing.
check the inside of your tailpipes for a thick black film, that
is a sign of it running rich.
check back with technosquare and let them look at it. they may have richened up the air/fuel ratio to much.
Injen CAI
Aluminum Pedals
06g35
Feb 14, 2022 05:59 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
MThawkins86
Oct 24, 2015 02:07 AM
G35VSHNG37
Sep 10, 2015 01:54 PM
