help me~ (MD 5/16" ISO Thermal plenum spacer)
Old Mar 26, 2006 | 02:46 AM
harmless52's Avatar
Smile help me~ (MD 5/16" ISO Thermal plenum spacer)
hello guys~
I need some help for intake maniford collector gasket.
Do I have to remove the stock intake maniford collector gasket(which is
placed on between lower and upper intake maniford collector. Not aramid
gasket)?? Or Can I reuse that maniford collector gasket with spacer and
spacer gasket(It means 2 gaskets between lower and upper intake maniford
collector)?
Which way is the best for the performance?
And should I coat spacer gasket with motor oil too?
Please reguard~
Thanx~
Old Mar 26, 2006 | 02:58 AM
Chucky's Avatar
Remove the old gasket and throw it out... and yes, coat the new one in oil before installing it.
Old Mar 26, 2006 | 05:03 AM
Andy2434's Avatar
If I understand your question correctly . . . I would reuse the stock gasket. You then would have the following assembly scenario: Lower collector, stock gasket, new 5/16" spacer, new gasket, top collector. I don't think you need to oil these metal type gaskets.
Old Mar 26, 2006 | 10:28 AM
thx007's Avatar
There are 3 stock gaskets you'll encounter when doing the ISO Thermal install. The first is the top plenum gasket which you'll find along the perimeter of where the top and lower plenums meet (you'll reuse it under your new spacer - new spacer has a forth gasket attached to top usually). The second (which I think you're asking about) is the one that has the center bolt holes in it and sits in the top of the lower plenum (you DON'T remove this at all). The third is under the lower plenum on top of the manifold (this is the one where you remove the metal stock gasket and replace with the new ISO Thermal one).
Don't reuse the metal gasket and yes, thinly coat the new gasket with motor oil. It is important.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
w4kj4k
Oct 2, 2015 07:57 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
