Pop Charger Malfunction?
Old Apr 1, 2006 | 11:03 PM
wakelawyer's Avatar
I have a question that I hope someone can help me with. I installed a pop charger and Z tube today. After installing them I forgot to reconnect the wiring harness to the piece that connects the Z tube to the pop charger. I got a malfunction message on my navigation. Surprisingly enough it was a VDC error which I thought had something to do with traction control. Anyway, I connected the harness but the error message still appears and the check engine light is on. Is there something I should look for? Could I have done damage to the car? Can I reset the check engine light and error message? If I do will the message come back if I really did screw something up? The car seems to run well, sounds great with the mods but I'm wondering if the deep throaty noise when I get above 4,000 rpms is the mod or something I should worry about (i.e. the engine not getting enough air).
I would appreciate any thoughts you may have.
Russ
Old Apr 1, 2006 | 11:19 PM
glennp_1999's Avatar
Reset the ECU that should take care of the problem.
Old Apr 2, 2006 | 12:08 AM
Andy2434's Avatar
When I was installing the Stillen Hi-Flow Airbox, there was a note per the install instructions. The note read, "Once the M.A.S. is disconnected do not start the vehicle, Check Engine light will go on and will need to be reset by a dealer." I do not know how true this is. However, as previously suggested . . . Perhaps a simple ECU reset will remedy your issue. Good luck!
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
