Just purchased the Autoenginuity OBDII w/ Nissan enhanced.
Old Jun 13, 2006 | 05:59 PM
  #76
Jeff92se's Avatar
Red Card Crew
One could monitor the 02s to see what voltages they are putting out. Plus it can monitor the actual a/f ratios also. Maybe the 02s aren't positioned the same, allowing them to send wrong signal to the ecu = rich condition. Not sure how this is related to the oil consumption. I'd put the factory cats back in and see if the problem clears up.
Old Jun 13, 2006 | 06:30 PM
  #77
_jb's Avatar
_jb
Photographer
That was my first thought too, but he didn't save the converters. He left them at the dealer and I'll bet someone grabbed them and sold them. That was about three weeks ago.
Would you have to monitor the O2 sensors in a stock G35 and then compare them to this particular G35, or could you just monitor the G35 with the problem and see that it doesn't follow a "standard" curve or something?
So this device would save having to make dyno pulls to check out the A/F ratio?
And this device will reset the ECU without having to do the gas pedal presses and other 12-step procedure?
Old Jun 13, 2006 | 06:52 PM
  #78
Jeff92se's Avatar
Red Card Crew
Well he could monitor the a/f and see if it's out of whack from the ratios being discussed in this site. Since tuners often tune down to about 12:1, I would imagine a super rich a/f would be 10:1 or lower.
I do believe it can handle ecu resets. It can do DTC resets.
Or he can compare with someone else that's datalogged their 02 voltages/ a/f ratios. But finding one would be hard.
Old Jun 13, 2006 | 06:58 PM
  #79
Foo_G's Avatar
Florida G35 Club, Premier Member
From: Universe.Milkyway.Solarsystem.Earth.NorthAmerica.USA.FL.Tampa
Hey _jb. I'd love to bring this out for a mini meet. Dan and I re going to catch up pretty soon to ret his timing for the nitrous system.
As Jeff mentioned voltage output would give you a good indication of testing lean or rich conditon.
My concern would be, as a novice I mind you, that he may already have damaged the O2 sensors if he is buring a lot of oil. The oil ash build up would skew the readings and may not be valid at this point.
I would love to get together with the Tampa folks oer his car and test and learn. I have access to some great knowledge resources which might help us come to a conclusion.
All there is is air and opportunity and we can burn up the air. Find out if he wants to spend some time on this and I will try to make my calendar fit the situation.
Old Jun 13, 2006 | 06:59 PM
  #80
Foo_G's Avatar
there is an ecu reset routine in the enhanced powertrain codes.
Old Jun 13, 2006 | 07:02 PM
  #81
Foo_G's Avatar
I wonder if the higher velocity exhaust is creating more of a vaccum out of the pcv resulting in more oil being sucked up into the plenum.
maybe bad rings and the oil is bypassing them.
Old Jun 13, 2006 | 07:15 PM
  #82
Foo_G's Avatar
Lube system flow chart.
Attached Thumbnails Just purchased the Autoenginuity OBDII w/ Nissan enhanced.-lube.sys.flow.chrt.jpg
Old Jun 13, 2006 | 07:37 PM
  #83
Foo_G's Avatar
after reading pcv operation I would be willing to bet that it is not cutting out the blow by valve like it should when at idle or low loads. Other options would be the rings, too much oil, oil too thin and other mechanical issues.
I really cannot see any other way the new exhaust system would be causing this to occur but I am an IT not a ASE mechanic.
Old Jun 13, 2006 | 09:12 PM
  #84
Foo_G's Avatar
reading from this http://www.carcarecouncil.org/Engine...ase_vent.shtml and many other articles I would think a constantly closed or open pcv would introduce excessive oil into the combustion process. I am placing my money on either a bad pcv or the balance of the crankcase ventilation is being usurped by some non oem component.
Old Jun 14, 2006 | 01:55 PM
  #85
_jb's Avatar
_jb
Photographer
Cool!
Why don't you think of a date and time that would be good for you. You'd be the one doing everyone the favor by bringing your equipment, you should get to select the time and place.
I wonder if you could clean off the o2 sensor with some mineral spirits or gasoline? I have to say that I am not very knowledgable about the environmental controls and ECU systems in modern cars. I used to race a simple small block Chevy, so I'm good on engine, trans, and rear ends, but that's about it. My main interest in this system is to learn how some of this stuff actually works.
I don't want to put you on the spot about analyzing Ben's car. We can just announce the Mini-Meet and see how it goes. I know Ben doesn't get too involved with working on his car.
Sounds good. Sorry for hijacking your thread a bit. Let me know on the date and place.
We should probably give everyone a few weeks notice. I made the last meet quick because I wanted to see Ben's exhaust and I think some people might have missed the notification.
Old Jun 14, 2006 | 02:06 PM
  #86
Foo_G's Avatar
I will start a thread in the FGC public forum. No worries on the thread issue as it is was nice to speak about how this tool can benefit owner ofthe G or anyother car.
  #87
_jb's Avatar
_jb
Photographer
This is exactly what some people are speculating! Ben said that he saw blue smoke coming out of his exhaust when he first had the pipes installed. Blue smoke is oil.
That's possible, but his G35 is an almost new 2006 and it didn't do it before he installed the test pipes and exhaust.
Mechanically, there seems like only two options that could cause this to happen... either the oil is pushing past the rings (as your mention) or it is being sucked down between the valve stems and the cylinder head. Both of these options would seem to be associated with wear.
I think the PCV option is more likely. I know PCV stands for Positive Cranckase Ventilation, but I'm not exactly sure how it works.
When I used to race, I used to run some tubing from the valve covers to the header collector to create a negative pressure in the crankcase and theoretically make the pistons go up and down more freely. Maybe PCV is something like this?
Old Jun 14, 2006 | 02:08 PM
  #88
_jb's Avatar
_jb
Photographer
Good idea. Thanks!
Old Jul 23, 2006 | 12:09 PM
  #89
Foo_G's Avatar
Hey guys
I have been away for a while due to a job change and recently caught with Mr. Horak via email again while registering the software on my new laptop and he had the following to say about the Nissan Infiniti OE codes.
Hey, did you see I sent you 4.3. It ahs full CAN BCM (including configuration settings). Also, we finalized the software for Nissan connections. Very much an improvement. Let your friends on the forum know this is available for beta testing. We release Aug 24th
• Added support for the Almera, Micra, Note, Patrol, Primera, Navara, Terrano, Versa models
• Added Self-Learn Control and Idle Air Volume Learn support
• Added CAN BCM support; including work support for Door Lock Unlock Set, Anti-LockOut Set, Horn Chirp
Set, Hazard Lamp Set, Multi-Answer Back Set, Auto-Lock Se, Panic Alarm Set, Trunk Open Set, Power Window
Down Set, Battery Saver Set, Custom Light Setting, Illumination Delay Set, Wiper Speed Setting, Reset
Setting Value, Room Lamp Timer Set, Security Alarm Set, Theft Alarm Trigger Erase)
• Improved CAN data rates by caching multi-packet responses
• Fixed Throttle Sensor 1 and 2 not working
• Fixed Accelerator Sensor 1 and 2 not working
• Fixed 4WD system Battery voltage sensor reporting incorrectly
I would like to add a thanks to Jay Horak for answering emails even on a Sunday afternoon. If you are thinking about investing in a scantool I implore you to check his product out. I have not been let down by him or his product yet and I have been a user for a long time now.
enjoy your sunday.
-nmp
Old Jul 23, 2006 | 02:27 PM
  #90
Foo_G's Avatar
Also, if you have the scantool already and want to test the latest build go to this link and DL the application.
http://www.autoenginuity.com/dloads/...antool_exe.zip
Just rename your current scantool.exe to scantool.old and save this new file in the same directory.
