anyone heard of KG/MM springs?
Old Sep 17, 2003 | 07:44 PM
tig488's Avatar
im buying a set of springs and cusco sway set from a guy for 500$, the springs have been used about a month and the sways have never been installed, decided to just get springs for now vs coilovers, the KG/MM DR21 Supersport Springs are for the 350Z but should be fine for the G, they are progressive and supposedly have a ride pretty similar to stock with about a 1" drop, they can be bought at bulletproofperformance for about 300$ so I think 500$ for the springs and new cuscos is pretty good, anyway I wanted to know if anyone was familiar with them?
2003.5 G35 Silver/Graphite 6MT Premium Coupe
Old Sep 17, 2003 | 10:07 PM
Gsedan35's Avatar
Re: anyone heard of KG/MM springs?
I can't say anything about the quality, all I can do I point out that their initial spring rate, just like the eibach's ment for the coupe are awfully soft.
(First number is the softet initial spring rate the next one is the higher final spring rate. Once the coilover bind on the spring, the higher rate takes over. Compair the final rate with the stock spring rates of, 347/419)
DR21 super sport 15mm drop
260/419 front 266/431 rear
Ivry 6mt sed
Crawford Pleneum
Injen CAI
22" resonator
Cusco sway bars
350Z springs&struts
Enkei RPM2
Old Sep 18, 2003 | 12:30 AM
s2k2sti's Avatar
i got kg/mm race springs on my s2000 and they are probably the best springs available for that car. next step up for those are probably getting coilovers.
i dunno if you should install springs meant for a 350 into a g35. are the weights of the car even the same? this plays a large role in how stiff the springs will be made.
Old Sep 18, 2003 | 10:34 AM
Gsedan35's Avatar
s2k2sti (Newbie)
09/17/03 09:30 PM
__________________________________________________ _
G35 coupes and 350Z's use the same spring rates from the factory. And the rate difference between the sedan with sport and the coupe and Z isn't enough blink over. Frankly, a bigger issue is how serious someone is and if progressive springs are a match to your driving style and if you willing to make the progressive spring compromise on performance and ultimate handling. So in that respect your certainly correct in the next step being coilovers, that would take you away from the progressive bit. I'd never use progressive springs on a car I drive,........period. Certainly the factory (Nissan) knew better.
Ivry 6mt sed
Crawford Pleneum
Injen CAI
22" resonator
Cusco sway bars
350Z springs&struts
Enkei RPM2
Old Sep 18, 2003 | 11:25 AM
tig488's Avatar
well, umm, that being said, what is better, dual rate(progressive) or single rate when it comes to ride quality? for this price, if i dont like them i guess i can sell them.
Old Feb 18, 2006 | 03:38 AM
james12's Avatar
KG/MM DR 21 questions
I got a set of KG/MM DR21 springs..its used from this other g35c..he said it dropped his car about 2.5 inches..just wonderin if these springs are good..or if they're too soft..should I sell it and get tein s-techs?
Dallsinghjr1
Sep 17, 2023 11:25 AM
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
dcsbh1
Oct 1, 2015 03:15 PM
