FS: TopSpeed Pro1 TRUE DUAL, my lost your gain
Old Feb 12, 2011 | 01:00 AM
_'s Avatar
_
FS or WTT: TopSpeed Pro1 TRUE DUAL
I just got these on 2/09/11.
Only ran 50 miles, no damage on them.
I want a different set up so I dont want this. there is nothing wrong with them.
You will need to buy your own bolts and gasket.
When the package was open
Installed. only ran 50 miles so far.
Had fitment issue is because i installed it wrong. And was too lazy to fix it.
The installer probably tighten the bolts on driver side and move on to passenger side this is why the passenger side exhaust is almost touching the bumper and is at higher position.
Kevin,
That exhaust shop made a very common mistake on installation, specially on dual exhaust set up.
The issue are caused the installer tighten the bolts on one side exhaust and moved on to other side, which will caused exhaust not line up due to stress are leaning toward the exhaust side that was tighten first.
You will need to loosen the bolts on both side exhaust, tighten the bolts on flange in rotation and have someone stand behind the car and guide you the position. This way the exhaust will be perfectly line up. Please make sure to revise you review after you had the issue corrected.
This is Top Speed Dual Exhaust Installation notes:
For All TOP SPEED PRO-1 Dual Exhaust Systems:
Special note for exhaust installation on the rear section exhaust installation, if you tighten the nuts&bolts on the exhaust on one side and move on to the other side the exhaust on left and right will not line up evenly and will be off in position.
Please tighten the nuts&bolts in rotation, right -> left -> right -> left and adjust the position of exhaust & exhaust hangers before tighten both side exhaust nuts&bolts.
For best results have a helper to stand behind the rear of your car to visually direct you to perfect installation.
Thank you for using TOP SPEED PRO-1 Exhaust System & Enjoy !
More information on this exhaust http://www.topspeedauto.com/ProductC...idproduct=2218
I can do trades as well. I can lower your price if you give me Test Pipes or Y-Pipe or BOTH.
Old Feb 12, 2011 | 01:04 AM
kennymo's Avatar
any chance you are willing to part it seperatly?
Old Feb 12, 2011 | 01:09 AM
_'s Avatar
_
No sorry this must need to go all together immediately and fast.
Old Feb 12, 2011 | 01:14 AM
_'s Avatar
_
Im taking all the parts out this weekend and it will be ready to be shipped. Local buyers is welcome to pick up in houston.
I can also upload a vid of how it sounds like on my set up.
Old Feb 12, 2011 | 01:26 AM
crashnburn's Avatar
sound clip and how much shipped to 32444
Old Feb 12, 2011 | 02:03 AM
_'s Avatar
_
PM sent.
Sound clip will be recorded tomorrow, i will keep this updated.
Old Feb 12, 2011 | 04:02 AM
_'s Avatar
_
Old Feb 12, 2011 | 11:53 AM
Swivel's Avatar
Moderator
As per forum rules, please include a picture with a handwritten sign with your screen name and the date. Once you're ready with that, PM me and I'll reopen the thread.
We just need to be sure that what you're selling is in your possession.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
thechitoguy
Oct 1, 2015 05:25 PM
