FS: 1320 test pipes
Received 2,462 Likes
on
Coupe 6MT Premium RAS
Yeah you have to double up non foulers, drill out the first set so the reduction is only in the first set, screw it all together and you should be good it'll look like this.
O2 sensor - 1st non fouler drilled out - second non fouler - test pipe.
EDIT: after looking at the picture they already have a long stem on the test pipe, probably just a single set of non-foulers will work.
I drove ttrank's car solo
Received 1,486 Likes
on
on
