FS: Motordyne MREV2
Old Sep 28, 2014 | 03:34 PM
Jhambor's Avatar
Exclamation Motordyne MREV2
Excellent condition Motordyne MREV2. What you see is what you get....nothing wrong with it. $450 shipped. Buy the Motordyne 5/16" spacer with it, and I'll cut you a better deal!
Check out my other post for lots of other parts available, including:
-Motordyne Plenum Spacer
-Motordyne MREV2
-Kinetix High Flow Cats
-Authentic NISMO oil and radiator caps
-JDM Driver side battery cover
-Authentic IMPUL shift ****
-Z1 Motorsports black intake Z tube
-Carbon fiber 350z half engine cover
-UPREV Osiris Basic software/license/ciphper wire
-GT Spec Front Upper Strut Bar
-Authentic JDM Dash Kit & A/C Controls for double DIN stereo install
Old Sep 28, 2014 | 05:22 PM
tha_ape's Avatar
G35 6MT Coupe
This should go fast, I just installed mine a couple weeks ago with 5/16 spacer and I definitely noticed the difference, a lot torquier through out the power band.
GLWS
EDIT: I noticed that MD only smooths out 2 of the ports. I was tempted to polish the whole thing smooth, but figured there might be a reason not to. At this point, I'm not removing it to do all that.
Old Sep 28, 2014 | 06:25 PM
xxflipxpryd3xx's Avatar
GLWS
What year is your car? I was wondering if these do anything for the 04 coupes.
Old Sep 28, 2014 | 06:52 PM
tha_ape's Avatar
G35 6MT Coupe
I have a 2006 6MT. I honestly dont know much about the earlier versions because I've been focused only on mine, but I do think it does something. I know there is a LOT of research done on MREV2 on both Rev-Up and non-rev up motors. From what I understand the spacer is key as well.
I opted for the copper iso thermal, no valve needed. I wanted to cut as little as possible and not have to worry about flipping a valve in cold/hot times. With the copper iso-thermal, there is no valve (no cutting of hoses), just hook it up and forget about it.
Old Sep 28, 2014 | 07:20 PM
Yeah that's what spacer I'm planning on getting. Thanks for the info. I'll do more research on the mrev for my car.
Old Sep 28, 2014 | 07:37 PM
Jhambor's Avatar
Mine is an '05 revup. I don't know the differences on this particular part year to year, so you might want to look into it yourself.
Old Sep 28, 2014 | 08:05 PM
Lartytiejdke3's Avatar
if you actually have an 04 coupe no need for this particular product. Revups weren't introduced for coupes until 05 with 6mts. Save your money
Old Sep 28, 2014 | 08:08 PM
Thank you.
Old Sep 28, 2014 | 08:56 PM
Matt6336's Avatar
GLWS
Are you tuned?
Old Oct 2, 2014 | 01:14 PM
usingthejohn's Avatar
Is this still available?
Old Oct 2, 2014 | 01:18 PM
Jhambor's Avatar
Yes, PM me if interested. Thanks.
Old Oct 4, 2014 | 02:30 PM
Jhambor's Avatar
sold
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
boostelevator
12
Jan 12, 2016 11:35 PM
bigmike
Sep 17, 2015 01:58 PM
