FS: GTM stage 2 Twin turbo kit
Hey, nice pics. Had a couple questions:
How many miles do the turbos have on them?
Does it include any (GTM) engine management, or did you run your own?
Does it come with injectors and a fuel pump?
Or what any other pieces would be needed?
From what I've seen, there's no difference in the kit for Rev-Up and Non motors correct?
Thanks
Thanks
It does not include any fuel system upgrades, But like I said in the post I wil have a complete RFS up for sale shortly. I also had a custom Uprev dyno tune, if you need a setup I can make that happen for a good price as well, but it is not included in the sale.
Turbos have 10k miles on them, do not smoke at all. I drove 300 miles round trip twice a week on the freeway for work In the summer and can't drive it in the winter since it always rains in the NW so lots of HW miles.
To run this the bare minimum would be Aftermarket MAF, injectors, fuel pump, and tune, I would recommend a return fuel system, twin disc clutch, boost controller, and guages tho.
I have a video of cold start up, idling, and driving over to the shop from the day I pulled the motor I'll try and post tonight
Thanks. Were you running it with a built motor? And how much boost?
I have a stock Rev-Up at the moment.
I've been looking for a complete package more or less that doesn't completely break the bank.
built bottom end, 18psi max. Usually around 14psi. You could run this if you kept the boost low, and always have room to turn it up later on.
I have EVERYTHING to make a reliable 500whp setup for sale (or soon to be once I get it off the car), its just not included with the kit for this price
Unfortunately I need something a little more "family friendly" and a LOT less "single girl friendly"... so its gotta go
![Bowrofl](https://g35driver.com/forums/images/smilies/bowrofl.gif)
All said and done this is an awesome kit. Definitely going to miss it.
yep, probably going to freshen it up with a new HG, seals, and such first though.
edit: or I might just sell it as is, will have to see how much free time I have
