Engine - Power Adders Forced Induction; Nitrous; SprintBooster; etc.
FS: G35/350z Modified Turbonetics Kit Single Turbo Kit
Old Jul 13, 2016 | 08:13 PM
josh.irvine.6's Avatar
PRICE DROP! 2500 Shipped! This isn't some crap ebay kit - good for safe, reliable power for stock internals.
For sale is a modified turbonetics kit with a custom Greddy EVO II Exhaust that was modified to the single turbo; the exhaust on this setup sounds amazing!! It was installed on a G35 but with some small modifications can be installed on a 350z very easily.
This is an easy kit to install and doesn't need the engine to be removed - simple for even the basic DIY'r to do in the driveway with a jack and stands.
Kit does not included any ECU/tune or high flow fuel pump - this is the catless version but a replacement cat pipe can be found at treadstoneperformance.com.
Included in the kit is the following:
Turbonetics T60-1 Turbo - No Shaft Play
Spearco Air-Air Intercooler
Raptor Blow-Off Valve
Turbonteics Evolution Wastegate
All Hot and Cold Piping
Dual Fan Intercooler Shrowd and Control Unit AEM Dry Flow Air Filter
Upgraded DeatschWerks 550cc Injectors
Upgraded AAM Oilpan Spacer w/ Fittings
Upgraded Stainless Steel Oil Feed Line
Upgraded Treadstone T3/T4 Turbo Blanket
Modified Greddy Evo II Exhaust for Single Turbo
All brackets and such are included but I'm sure it's missing some nuts/bolts that can be picked up anywhere
Attached Thumbnails G35/350z Modified Turbonetics Kit Single Turbo Kit-date.jpg   G35/350z Modified Turbonetics Kit Single Turbo Kit-wastegate.jpg   G35/350z Modified Turbonetics Kit Single Turbo Kit-turbo.jpg   G35/350z Modified Turbonetics Kit Single Turbo Kit-turbo-lines.jpg   G35/350z Modified Turbonetics Kit Single Turbo Kit-oil-spacer.jpg
G35/350z Modified Turbonetics Kit Single Turbo Kit-intercooler.jpg   G35/350z Modified Turbonetics Kit Single Turbo Kit-injectors.jpg   G35/350z Modified Turbonetics Kit Single Turbo Kit-exhaust.jpg   G35/350z Modified Turbonetics Kit Single Turbo Kit-everything.jpg   G35/350z Modified Turbonetics Kit Single Turbo Kit-bov.jpg
Old Jul 18, 2016 | 02:06 PM
Bump! Make me a reasonable offer via PM and let's see what we can do.
Old Jul 21, 2016 | 07:10 PM
Bump.
Old Jul 24, 2016 | 09:52 PM
Price drop! 2800 shipped!
Old Aug 1, 2016 | 11:03 PM
Price dropped again.. 2500 shipped!!
Old Aug 5, 2016 | 09:43 AM
Troysilver's Avatar
What were you making with this kit?
Old Aug 5, 2016 | 02:08 PM
I was right around 360whp and slightly higher wtq.. fun car
Old Aug 5, 2016 | 02:10 PM
g35wheels's Avatar
modified in what way? would fit onto a vortech set up? if so how much shipped to fl?
Old Aug 6, 2016 | 12:59 AM
Basically they took the cat delete pipe and welded the exhaust directly to it so that where the OEM cat would hook up to the exhaust, it's all one now - it should work for your vehicle but I'm not sure.
Old Aug 7, 2016 | 11:22 PM
Bump! Still for sale.
Old Aug 9, 2016 | 09:57 PM
Pending sale.
Old Aug 11, 2016 | 04:09 AM
TheX's Avatar
G35x
Would this fit on a g35x 2005?
Old Aug 11, 2016 | 10:21 AM
Yes it will fit your vehicle.
Old Aug 11, 2016 | 10:51 AM
Bump still for sale - buyer fell through.
Old Aug 12, 2016 | 08:08 PM
Sold!
Tunerz_Store
Exhaust-Vendor
20
Oct 1, 2017 09:54 PM
clearwaterms
Jul 15, 2016 01:11 PM
sliverg35
Forced Induction
Jul 10, 2016 12:46 PM
QX1
Jul 8, 2016 07:15 PM
